R56 Coolant issues
Old Apr 11, 2014 | 04:13 AM
Whitt's Avatar
Whitt
From: From Michigan, United States, Currently living in Germany
Coolant issues
So i purchased an american spec mini while here in germany. Shortly after buying the car i started to do some aftermarket work to it. First thing i did to it was a NM cold air intake. Then shortly after installing it, the engine light came on, i assumed it was an emission code but after i scanned it, the code that came up was P1028; engine running too cold.so i took it to the dealership and they replaced the thermostat housing. It happened again and they replaced the thermostat housing again, now the light is back on it and saying the same code. Engine too cold. Any ideas? or thoughts on what the hell is causing this and more importantly is this a major issue that can cause damage?
Old Apr 11, 2014 | 10:12 AM
countryboyshane's Avatar
countryboyshane
Greetings from Oakland Township!
Take the intake off and see if it does the same thing.
Old Apr 11, 2014 | 11:10 AM
Porthos's Avatar
Porthos
+1. Though when will BMW learn that plastic thermostat housing are complete crap and that they need to go aluminum? My 93 5 series had plastic and that think went like 3 days after I bought it.
Old Apr 14, 2014 | 01:55 AM
Whitt's Avatar
Whitt
hello to a fellow michigander! thank you, ill try it. But what doe the intake have to do with the engine being too cold?
Old Apr 15, 2014 | 01:04 PM
Summons's Avatar
Summons
While it COULD be the housing again, I'd have a close look at the harnesses...
Go on the hunt for chafed wires, damaged or contaminated connectors, pulled or bent pins.
Check closely around the cold air intake, as that area was disturbed prior the fault appearing.
Good luck!
E
Old Apr 16, 2014 | 12:37 AM
Whitt's Avatar
Whitt
Okay great, i didn't think of that. ill get right it! Thanks Summons
Old Apr 16, 2014 | 12:43 AM
Systemlord's Avatar
Systemlord
At least Mini got it half right with the new aluminum main water pumps, I guess they didn't get the memo for the thermostat housing even when last summer people were without their Mini's for 3-4 months because of stock issues.
Old Apr 16, 2014 | 04:29 AM
countryboyshane
Another question here is when the engine is at operating temperature, and you clear the code, does it come back?
Old Apr 16, 2014 | 05:04 AM
v10climber's Avatar
v10climber
Our mini had some corrosion in the wiring harness around the thermostat. The dealer replaced the thermostat and a chunk of the wiring under warranty.
Kimolaoha
Jul 5, 2023 01:04 PM
speedyg56
May 18, 2020 08:52 AM
W0TM8
Dec 19, 2019 07:50 AM
Steffen.Johnson
Aug 23, 2015 08:30 PM
tylewis
Aug 18, 2015 06:53 AM
