R50/53 AC pressure switch
Old Apr 10, 2014 | 06:39 PM
jaycobb38's Avatar
jaycobb38
AC pressure switch
My AC quit working at the end of the summer last year. Had a mechanic check it out a couple days ago and he said it's the pressure switch. I know the clutches go bad in these so before I spend the money on a unit, I want to try the cheaper option and change the pressure switch first. So my question is, can the switch be changed without having the freon removed, or do I have to have the system evacuated?
Old Apr 11, 2014 | 09:50 AM
racingbmwm3's Avatar
racingbmwm3
ANY AC work is going to require evacuating the system. Unless you have the vacuum/AC tools, I recommend having a shop do all AC work.
Old Apr 11, 2014 | 10:18 AM
ZippyNH's Avatar
ZippyNH
IF the AC system is opened up....the drier should be REPLACED...moisture..en just from ambient air is a MAJOR issue..both in efficiency and wear...that is one of the reasons WHY the system is vacuumed BEFORE refilling....leftover air also results(along with the mentioned moisture) can result is VERY poor performance.....
Old Jun 4, 2024 | 10:26 PM
tmc5150's Avatar
tmc5150
You might need it recovered
My 2002 mini cooper it was necessary because no check valve under the switch.
Old Jun 15, 2024 | 10:21 AM
Tombstone's Avatar
Tombstone
It’s seems like a bad design by BMW for not installing a schrader valve behind the pressure switch , like GM , Ford & Chrysler does ?
hvymtlc5
Jun 5, 2024 05:03 AM
WheelNut
Sep 15, 2021 03:53 PM
peteaball
Jul 12, 2016 10:02 AM
realeyezsoul
Electrical
Mar 30, 2009 03:39 AM
