Rear Camber and Tires
Old Apr 2, 2014 | 08:13 PM
Mrlively79's Avatar
Mrlively79
Had to stop at a regular repair shop for a tire while on vacation. During an alignment check it was noted that the rear camber is more than a degree out of spec (negative). There doesn't seem to be a way to adjust rear camber (fixed arm). With 24K miles and already on a 2nd set of tires and a new rim (potholes from winter), I wonder what I've gotten myself into. Average driving is less than 15 miles a day at no more than 60 mph for my wife's short commute to work. Anybody else have these problems???
Old Apr 2, 2014 | 08:45 PM
CarlosDMotor's Avatar
CarlosDMotor
There is an eggcentric bolt on the rear lower control arm connecting it to the trailing arm... used to adjust camber. Adjustable rear control arms will also do the trick
Old Apr 3, 2014 | 04:50 AM
v10climber's Avatar
v10climber
The rear camber is adjustable with the eccentric bolt. It's where the lower camber link bolts to the control arm.
When they measured the camber was there a bunch of stuff piled in the trunk/backseat from the trip? That could really screw with the alignment numbers. You shouldn't be going through tires that fast though so something is up.
Old Apr 10, 2014 | 05:44 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
See post #4
https://www.northamericanmotoring.co...ar-camber.html
Old Apr 11, 2014 | 06:04 AM
Chili_head's Avatar
Chili_head
R56? 05-06 R53? Early R53?
Early R53's have no stock adjustment. Adjustable control arms are the answer.
W0TM8
Dec 19, 2019 07:50 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
