R56 battery terminal replacement!?
Old Apr 1, 2014 | 02:35 AM
Visionaire's Avatar
Visionaire
I recently purchased a new battery for my 08mcs and when installing the new battery I noticed the terminals did not clamp tight enough around the battery. They can easily be disconnected even when tightened fully.
Is it as easy as just cutting the terminals off and installing new ones such as these below?http://contentinfo.autozone.com/znet...06071/image/3/
Old Apr 1, 2014 | 12:55 PM
ammodave's Avatar
ammodave
You could replace the connectors or you could just shim the new terminals with something like this http://www.autozone.com/autozone/acc...ntifier=257147 or your own diy equivalent. There's nothing wrong with your oem battery connectors; unfortunately your new battery has undersized terminals. I'd try the shims first.
Old Apr 1, 2014 | 03:44 PM
Visionaire's Avatar
Visionaire
Have already given the shims a shot but they now leave the terminal too big to allow the oem connectors to slide over. I just want to ensure these connectors can be replaced without any lights being thrown. A mini specialty shop here in N. Hollywood told me id throw an airbag light if I changed them? Sounds illegitimate but want to be sure.
Old Apr 1, 2014 | 03:54 PM
Capt_bj's Avatar
Capt_bj
I used a slab of copper to shim mine
if the store boughts are too big .... file them down or spread the car connector (with a screw driver ... not complicated)
stevepsd
35
Dec 6, 2022 03:22 PM
woodstudio
Mar 15, 2020 08:28 AM
Teh
Jun 13, 2018 02:59 PM
scottrn
Aug 22, 2015 07:26 PM
jeremy_reyes94
Aug 12, 2015 10:56 AM
