Check engine light and air filter
Old Mar 25, 2014 | 09:55 AM
StillK's Avatar
StillK
Several times this winter the check engine light has come on - 11 Cooper. It always happened when the temperature hovered around 0 or below - typically happened after driving only a mile or so. The mechanic where I take my car to said that he could not retrieve any codes once the car has been restarted twice. I don't know if this is an excuse not to check for a code or if this is really true. At the time the car ran OK - the light would go off once the car warmed up. Is this a sign of impending doom - large repair bill - or a product of the damn cold weather?
Also at the last oil change I asked him to check the air filter. He told me that the air filter does not typically need to be changed and is essentially life time. Sounds strange to me - do I need to look for a new mechanic? I usually do my own oil changes but it has been to cold to work in an unheated garage. If the air filter does in fact need to be changed is this a big deal?
Old Mar 25, 2014 | 10:11 AM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Yes, you do.
Very easy.
Old Mar 28, 2014 | 06:49 AM
Unless it was a aftermarket drop in K&N / aFe and it needs washed or cleaned every so often. That's what the mechanic might have meant. Take a picture of it and post it.
Is your 2011 MINI a Cooper ( Non S ) or Cooper S ( Turbo ) ?
If its a regular stock MINI filter, then I would be concerned.
The CEL coming on might be a stumble from verycold temps and throttle body ice issues. Usually from short trips.
silence2-38554
98
Sep 21, 2016 02:52 PM
minipopkart
Aug 13, 2015 05:22 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
