Anything like this for a MINI
Old Mar 24, 2014 | 07:37 PM
navybsn's Avatar
navybsn
Picture below. Looking for a wheel with a "deep" center (not sure if that's the right term). This pic is from a 370z, but I've seen the same look on BMWs too. Doesn't have to be the exact wheel, just the same sort of look.
Old Mar 24, 2014 | 09:30 PM
GEMSTER's Avatar
GEMSTER
The term is "concave".
It doesn't work on a MINI because there isnt enough room in the fender for wide wheels that are deep concave. If you want a concave wheel like the one you posted, you will need 9+ inch wheels.
It is possible to fit 9inch wide wheels in your MINI, but you will either need to run wide fenders, or have a massive amount of negative camber to make the wheels "fit" in the fender.
Of course there are wheels under 9 inch that have a very slight concave face to them, but no where as concave as those.
The Breyton GTS-R for the MINI is slightly concave. (Combfilter's R56)
Rotiform NUE is also slighly concave (Creeve's R56)
Old Mar 25, 2014 | 05:41 AM
Grizld700's Avatar
Grizld700
Unrelated to the question at hand, but I'd like like to know how Creeve made his halogens have a dark housing! I figured if you darkened the halogen housing then it wouldn't really light up in front of you.
Old Mar 25, 2014 | 08:23 AM
navybsn's Avatar
navybsn
I may be mistaken, but I think that's tint on the headlight lenses.
I figured that it would need to be a fairly wide wheel to get that look. 9" is too much for me. Not really interested in negative camber or wider fender wells. I do like the look of those Rotiforms. Might look closer at those.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
