R56 Lowered Rides Check Your A/C Coolant Line
Old Mar 18, 2014 | 10:52 AM
teleautomata's Avatar
teleautomata
My 07 R56 A/C suddenly stopped working after I heard what sounded like a flat tire. So I jacked the car up and put the front wheels on some rhino ramps. I noticed that the passenger side axle was rubbing against the A/C coolant hose.
It's part number 3 on this link :http://realoem.com/bmw/showparts.do?...40&hg=64&fg=60
I jacked up the passenger side, removed the wheel, and some portions of the fender liner to access the lower side. To get to the higher side of the hose, just remove your airbox, and also sound generator.
Attached Thumbnails Lowered Rides Check Your A/C Coolant Line-photo.jpg
Old Mar 18, 2014 | 02:12 PM
Systemlord's Avatar
Systemlord
How many inches did you drop your 07 MCS? Thanks for the headsup.
Old Mar 18, 2014 | 10:00 PM
teleautomata
I'm on h&r coilovers, and dropped approximately 1.5 inches all the way around.
Old Mar 19, 2014 | 01:54 AM
mbwicz's Avatar
mbwicz
I noticed that mine was wearing, and I'm only on TSW springs. A couple of zip ties has it tucked up out of the way. You can see if there is a shiny or worn spot on the axle when you have the wheel off, the line is hidden unless you know where to look.
Mike
Old Mar 19, 2014 | 09:10 AM
cantcode86's Avatar
cantcode86
I'm kind of surprised that this is just now coming up. I thought I had just missed this info somewhere. Check out the driver side too. I notice that the axle was kind of close to the clutch hydraulic line. I have no idea how much I lowered my car. I just set it up where I thought that I liked it.
Old Mar 22, 2014 | 01:03 AM
elsenordave's Avatar
elsenordave
I checked no issues on mine thus far...thx for the heads up!
Old Mar 22, 2014 | 10:45 PM
Porthos's Avatar
Porthos
I just had mine at the mechanic and they didn't say anything. I will take a look just to make sure.
Kimolaoha
Jul 5, 2023 01:04 PM
W0TM8
Dec 19, 2019 07:50 AM
theblackfalcon
Oct 11, 2015 09:49 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Emnotek
Aug 13, 2015 05:47 PM
