R56 Help Installing Rear View Mirror Cover
Old Mar 16, 2014 | 03:11 PM
mcjome's Avatar
mcjome
Hello all, could anyone tell me or direct me to instructions on how to install
these rear view mirror caps? these rear view mirror caps?
Thanks!
Old Mar 17, 2014 | 10:14 AM
They are easy to install. What year and options R56 MINI do you have? The two main differences are the auto/ manual dim and if you have the universal garage door opener on the bottom.
They all come with double sides tape which you peal and stick. They fit tight and the manual dim ones have a hole in the bottom for the dip switch.
Old Mar 17, 2014 | 11:12 AM
Charlie Victor's Avatar
Charlie Victor
The OEM cap I bought had the adhesive already installed along the inside. The tricky part is just getting the upper edge in place before letting the adhesive come in contact with the mirror housing. It's not as hard as it sounds. You can try a trial fitting before you peel the tape covering off. Good luck!
Old Mar 17, 2014 | 01:20 PM
bmwr606's Avatar
bmwr606
i just popped mine on for a test fit, did not even uncover the sticky tape ... it fit so well that i left it on, it is not glued at all ... been on almost 2 years now
Dec 23, 2015 10:36 AM
dyeLucky
Sep 11, 2015 10:41 AM
The_Kid
Aug 16, 2015 11:13 AM
dyeLucky
Aug 7, 2015 07:10 AM
bctf1
Aug 6, 2015 12:55 PM
