R56 Can you use a vacuum bleeder on an R56???
Old Mar 15, 2014 | 05:53 PM
honda93's Avatar
honda93
I have a Vacula brake bleeder...
http://www.ebay.com/itm/BRAKE-FLUID-VACUUM-BLEEDER-VACULA-MITYVAC-TYPE-TOOLS-MERCEDES-BMW-VW-AUDI-HONDA-/261270287851?pt=Motors_Automotive_Tools&hash=item3cd4ec35eb&vxp=mtr
It works wonders on any of the Japanese and domestic brands I've done brakes on, but I've heard the BMW/MINI setup doesn't like/tolerate the vacuum systems. Has anyone used an air-based vacuum bleeder on an R56?
This would make doing the brakes and clutch a piece of cake, but I'm not about to experiment without doing research first.
Old Mar 16, 2014 | 04:54 AM
JR2012IBB's Avatar
JR2012IBB
For what it's worth I had an Audi and that kind of device worked fine on the brakes but not on the clutch. The slave cylinder needed more pressure and required a pressure bleeder. The vacuum bleeder also worked fine on my Cayenne. I did invest in a pressure bleeder because of the Audi clutch so I'll be using that on the MINI.
Old Mar 16, 2014 | 05:42 AM
danjreed's Avatar
danjreed
Yes, it works fine on Minis.
Old Mar 16, 2014 | 05:50 PM
honda93's Avatar
honda93
Thanks guys!
While we're on the topic... What's the bleed procedure? (i.e. LR, RF, RR, RF?)
Old Mar 16, 2014 | 08:17 PM
trwxxa's Avatar
trwxxa
Originally Posted by honda93
Thanks guys!
Always start bleeding from the point farthest from the resevoir, and work your way closer to it -- RR, LR, RF, then LF.
Old Mar 17, 2014 | 08:36 AM
dmyer's Avatar
dmyer
I have a simlar Vacumn bleeder that runs off my air compressor. Works AOK on mini although if I bought again I would get the pressure bleeder as it is faster IMO.
rtk90
Aug 29, 2019 09:08 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 9, 2015 01:37 PM
PelicanParts.com
Accessory Products
Sep 3, 2015 08:54 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
