Interior/Exterior Broken antenna mount. Options?
Old Mar 15, 2014 | 01:37 PM
barenada's Avatar
barenada
A car wash broke my antenna mount on my 2005 MINI S. So now I need to replace it. I could, of course, replace it with an identical part, but I'm wondering what other options I might have.
Old Mar 15, 2014 | 02:25 PM
Capt_bj's Avatar
Capt_bj
you COULD go to a hidden mount, but if you take off the original one (which requires getting behind the headliner) you'll have a hole in the roof to deal with . . .
A replacement mount if you do not have nav or blue can be found for about $50 and with $150 .... and install still requires getting inside the headliner....
http://www.ecstuning.com/Mini-2007-C...rior/Antennas/
btw ... how does your radio work w/out the ant? Sounds like a silly question but on a GEN2 .... loss of the ant has little impact on FM reception according to someone I'm working with in another board with the same problem on a 2009 . . . seems the roof mast is not the ONLY antenna . . .
Old Mar 15, 2014 | 05:17 PM
barenada's Avatar
barenada
My radio seems to work fine on FM. AM isn't as good, but it never has been.
From some articles I've been reading, it seems that since my car has a sunroof I might have a somewhat easy time of replacing this thing. There's a panel that, I'm told, is right under my antenna mount on my car. I haven't pulled the panel off to check yet.
I'm curious at what options I might have. Like maybe there's some shark-fin antenna that's an easy enough replacement.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
