R60 Cold auto tranny
Old Mar 13, 2014 | 02:34 PM
wvmtnbiker's Avatar
wvmtnbiker
Cold auto tranny
So today it was 13 degrees this am. It got to 31 this afternoon. Here's the issue. When I went out to leave work, car started normally but for the life of me I could not get the auto shifter out of park. Car was parked dead level. After I finally got it into drive it was smooth sailing all the way home. When I tried the shifter then, it moved easily like it should.
Does cold weather affect these trannys like this? I just bought the car as a CPO car from a Mini dealer. So it should be fine with only 11K on the clock.
Thoughts?
Old Mar 13, 2014 | 05:13 PM
mikey_t's Avatar
mikey_t
I know that my auto tranny is a bit slow to respond when its cold out but i've never had the problem of not being able to get it into gear. Perhaps the brake switch wasn't functioning properly so that you couldn't move the shifter out of park?
Old Mar 14, 2014 | 11:28 AM
hoonu's Avatar
hoonu
Same experience as mikey_t. It seems to hold the first shift a little long, and it almost seems like the hill assist "drags" a mite at first, especially if the first move is to back up. No issue with P-D shift. HTH.
Old Mar 15, 2014 | 07:12 PM
gchin's Avatar
gchin
Does an auto trans have any mechanical linkage to shift?
Or is it all done with switches in the floor shift mechanism?
boholio
Nov 9, 2015 03:50 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
Vaderm34
Sep 27, 2015 09:25 PM
CandorLush
Sep 13, 2015 06:42 PM
dandw2
Sep 7, 2015 11:14 AM
