Suspension Control Arm bushing video needed
Old Mar 8, 2014 | 01:59 PM
MarioKart's Avatar
MarioKart
Vendor
I'm replacing front control arm bushings. Does anyone have a really good step by step or video instructions? Also, should I just buy OEM bushings?
Mario
Sent from my iPhone Office
Old Mar 11, 2014 | 03:56 PM
countryboyshane's Avatar
countryboyshane
If you go to the NAM homepage and look up NAM Alliance issues (there are five total) Detroit Tuned did a DIY article with lots of pictures showing how to do it. That's what I used.
Do not go back to stock bushings! They are soft rubbery ****!
Go to the Powerflex. You will not regret it!
Old Mar 11, 2014 | 04:18 PM
jkapinos's Avatar
jkapinos
What's wrong with your bushings?. Your car is new.
Old Mar 11, 2014 | 04:22 PM
CORNERS's Avatar
CORNERS
Here you go.
Not a full step by step (camera wasn't recording for the first half of the job - argh) but hope it helps.
This is for an R53 but the procedure should be very similar for an R56.
Old Mar 11, 2014 | 07:12 PM
MarioKart's Avatar
MarioKart
Vendor
That's is extremely helpful video!! I have a torch, and a saw, if you had the choice, do you think the torch would be faster?
Thank you
Mario
Old Mar 11, 2014 | 07:15 PM
countryboyshane
Oh boy good luck. I would be puckering so bad using a torch down there. It's probably on your mind but dang be careful Most shops drop the subframe or use a special tool to push out and press in the new bushing.
Old Mar 11, 2014 | 07:20 PM
CORNERS's Avatar
CORNERS
Hi - I would not be confident using such a hot torch under there. I would probably set the body undercoating on fire. If your skilled with a torch, go for it.
The cutting method takes maybe 3-4 minutes worth of cutting per side. I suspect the time investment is similar for each.
Choose your method with the following pros/cons:
Electricity is cheaper than gas
No chance of setting anything on fire with a saw
You need to carefully monitor your cutting progress and ensure the saw blade is level from front to rear, to avoid cutting through the bushing carrier/bracket.
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
