R56 Water Pipe
Old Mar 5, 2014 | 09:38 AM
ACTE's Avatar
ACTE
Water Pipe
Ive been having a coolant leak for a month or so and have to fill the coolant every 2 or 3 weeks. I was told that my water pipe has crack by the water pump. What is the easiest way to access the water pipe so I can change it out myself?
Old Mar 5, 2014 | 11:04 AM
Hello ACTE,
Check to make sure its the water pipe and not the seals between or the water pump ( passenger side ) or the thermostat housing ( driver side ). The water pipe connects between the two and the thermostat housing will have to come out to access it behind / under the intake manifold.
https://www.northamericanmotoring.co...ater-tube.html
Here is the thread for the water pump and the thermostat housing leaks and locations/ install.
https://www.northamericanmotoring.co...t-leak-or.html
Thanks and hope that helps. That will give you a list of items to check out and make sure its the water pipe / water tube.
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
Doc Pain
Oct 28, 2015 07:09 PM
vetsvette
Oct 11, 2015 06:05 PM
BossyR56
Sep 28, 2015 11:33 AM
