R52 2006 mini cabrio recommended service
Old Mar 4, 2014 | 07:03 AM
timstrong21's Avatar
timstrong21
I tried the search function briefly with limited success. My wife has a 2006 cabrio with 100,000 miles on it. I bought it used and have changed the fluids regularly. Just wanted to know what major service would likely needs to be done? Does it have a timing belt or chain, do I need to replace the water pump etc. I appreciate the help and thanks in advance.
Old Mar 4, 2014 | 08:56 AM
Fly'n Brick's Avatar
Fly'n Brick
At 100K I would be paying close attention to hoses, pan gasket, bushings especially strut tower bushings, steering gear, when was the last time brake fluid was replaced. Other stuff; plugs, filters, brake pads & discs and the SC belt are normal wear items to be watched over constantly anyway. The W11 engine and Getrag gear box are both near bullet proof so just treat them nicely. The top should not be cycled if it is dirty as dirt and grit will cut the fabric. Best cleaners are Ragg Topp and 303. Rotate the tires at about 5k, otherwise you will see excessive wear on the inside of the rear tires due to negative camber. Bi-directional tires that can be crossed will afford the best wear. Get her a 'LightinSight' from either http://www.lightinsight.com/ or Way Motor Works.
Another good thing to pay close attention to is the pilot.
Here are some URLs for your collection of MINI resources:
http://soopercooperinfo.com/
http://www.toptiergas.com/retailers.html
http://www.realoem.com/bmw/partgrp.d...3&mospid=48019
http://www.motorcycleroads.us/index.html
Old Mar 4, 2014 | 06:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
100k we would do:
Fuel Filter
Drive Belt
Plug Wires
Spark Plugs
Oil and Filter change
A/C filter
then inspect it for anything else that may need service.
Old Mar 5, 2014 | 05:31 AM
timstrong21
Does the 2006 mini cabrio (non-s) have a timing belt or chain. If it has a belt when is it recommended to be changed? Thanks again for the advice.
Old Mar 5, 2014 | 05:49 AM
buzzsaw's Avatar
buzzsaw
Chain: http://www.waymotorworks.com/timing-...r-r50-r53.html
Old Mar 5, 2014 | 07:38 PM
WayMotorWorks
Vendor
It is a chain setup so there is no interval to change it. They are pretty reliable and don't usually break.
Old Mar 5, 2014 | 09:08 PM
Fly'n Brick
What Way said...near bullet proof as compared to the Prince thingie they put in the '08s.
Old Mar 12, 2014 | 10:35 AM
timstrong21
What is the typical price range for this (2006 mini cabrio "non-s"
SosoMINI
Nov 22, 2015 03:17 PM
minicoclub
Nov 11, 2015 07:25 AM
CARdiac
Aug 8, 2015 03:30 PM
sungjk
Aug 5, 2015 08:23 PM
rphox2003
Aug 5, 2015 11:34 AM
