R56 Oil Light on Hard Right Turns
Old Mar 2, 2014 | 06:29 AM
switch's Avatar
switch
I did some spirited driving yesterday and began getting a low oil light on hard right turns. Hard lefts had no effect. I pulled over and checked the oil and it was full.
Later the same day, I got a CEL P0340 which is a Camshaft Position Sensor. My theory is that on a hard right turn, the G forces pushed the oil away from the right side of the car/motor and the timing chain jumped a tooth.
Any thoughts? Has this happened to anyone else?
I'll post pictures of the dipstick readings soon.
Old Mar 2, 2014 | 06:36 AM
zrickety's Avatar
zrickety
Do you have any startup rattles? Could be debris blocking the oil pickup if the level is truly full.
Old Mar 2, 2014 | 06:47 AM
switch's Avatar
switch
I'll get a video later today. Nothing noticeable from the driver's seat.
Old Mar 2, 2014 | 10:58 AM
switch's Avatar
switch
Before going any further... I blame the dipstick.
About a week ago I checked the oil. According to the dipstick it was full. Yesterday, when I got the low oil pressure indicator I checked again. Dipstick showed full.
I changed my oil this morning. The Mini had 1.5 quarts in it...
Thinking that perhaps I just can't tell the nuances of the dipstick, I checked it again after the oil change. I couldn't tell a difference between yesterday and today.
Now I need to figure out where the oil is going. There are no marks in my garage, so I suppose the only other option is that it's burning oil.
I've ordered the CravenSpeed dipstick. It's pricey, but if it prevents me from blowing my car up, I suppose it's worth it. It's also going to the dealership tomorrow for Service. Hopefully we figure it out.
Videos (pre-oil change):
Old Mar 2, 2014 | 12:15 PM
countryboyshane's Avatar
countryboyshane
You didn't read the dipstick correctly. That has to be it. It doesn't matter what dipstick is in the N14/N18 engine. Oil gets whipped up into the tube where the stick resides and you'll get a bad reading unless you dip/wipe many many many times to get the residual oil out of the tube. I don't care if the Craven stick is in there, the root of the problem is the oil sneaking up the tube.
Old Mar 2, 2014 | 12:34 PM
mbwicz's Avatar
mbwicz
When I need to check the oil, I wait until I'm home. I pull the stick, wipe it off, and leave it on top of the engine. Then I go eat dinner, mow the lawn, whatever. I wait at least an hour (more is better), wipe it again, full insert, and check. This first check will be the most accurate.
Like shane said above, the dipstick runs in a tube that fills with oil. If you pull the stick when the tube did not have time to drain, it will deposit oil on the stick. If you check oil 3 or 4 times, each time that you pull the stick out, some of the oil sticks on that tube, and makes the reading inaccurate.
Just another pain that we have to go through to enjoy a MINI. Is this the modern version of what guys went through in the 60's with British roadsters?
Have fun,
Mike
Old Mar 2, 2014 | 01:49 PM
kg4fxg's Avatar
kg4fxg
Two Wheels
I get all sorts of lights corning hard and riding several blocks on just two wheels.
Sorry, could not resist!
Sounds like the dipstick issue and will be resolved with a new one. I don't freak of temporary lights but if they stay on constant that is another matter.
Try driving on two wheels it is a blast.
Old Mar 2, 2014 | 01:51 PM
kg4fxg's Avatar
kg4fxg
Filling the Oil...
Here is a primer on how to fill the oil in a Mini. Sorry, I could not resist. Have to have a sense of humor
Old Mar 2, 2014 | 02:07 PM
bjcarter2's Avatar
bjcarter2
I'll just leave this right here and walk away...
Old Mar 2, 2014 | 02:11 PM
Systemlord's Avatar
Systemlord
The Craven dipstick doesn't have problems with dragging oil up the tube where the stick is housed because it doesn't have the metal collar on the bottom of dipstick that drags oil up. I get the exact same oil reading every time with the Craven dipstick, that is what make it worth every penny!
There is no way that you did not cause excessive wear and tear on your engine running with 1.5 quarts! Your valvetrain most likely suffered! The N14 engines are known for consuming oil because the oil turns to vapor and enters the combustion chambers, the N18 are better at dealing with oil vapor escaping the PCV system.
Old Mar 2, 2014 | 02:14 PM
bmwr606's Avatar
bmwr606
i have the craven dipstick, it is much easier to read, but what i do is read the oil level first thing in the AM before driving the car
before everyone jumps on me for reading the level cold instead of hot, it makes less than 1/16 inch difference on the dipstick and is very easy to read!
Old Mar 2, 2014 | 02:36 PM
switch's Avatar
switch
I don't doubt it. There's not a lot I can do about it now.
Old Mar 2, 2014 | 02:42 PM
kg4fxg's Avatar
kg4fxg
+1
http://youtu.be/Mj5ms9PJDNY
Love it thanks. Gotta have a sense of humor - WOW!
Old Mar 2, 2014 | 07:49 PM
ashchuckton's Avatar
ashchuckton
Keep an eye on the oil level. Your MINI did not lose that much oil overnight it happened over time. Check your oil every week or so. I hope you didn't fark up the engine.
Good luck.
Old Mar 3, 2014 | 08:55 AM
switch's Avatar
switch
Yeah, I still hold that the dipstick is poorly designed. I should be able to park the car after driving, remove the dipstick and wipe it, re-insert it and pull it out to get an accurate reading. None of this waiting an hour for the oil to go down the tube, etc.
Old Mar 3, 2014 | 10:31 AM
bmx045's Avatar
bmx045
pull the dipstick out quick, wipe it, quickly push it down the tube all the way and immediately pull it quick out. view oil level at lowest point with dry plastic adjacent to it.
Wohnson89
Jun 10, 2020 04:53 AM
Teh
Jun 13, 2018 02:59 PM
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
