R56 BMS Clutch Pedal Stop
Old Feb 11, 2014 | 08:16 PM
stronzo2's Avatar
stronzo2
It seems to be a very popular little gadget, unfortunately my 2010 S does not have the little plug I can swap the thing with. I looked...for a looong time...with a bright drop light, with the clutch pedal right in my face. It's not there. I can see the track mark of the pedal arm where it made a dent in the black carpet...I followed that, no plastic bump stop. Stuck my fingers behind the carpet's, no bump stop. What I did find however, is that where the clutch pedal arm hits the carpet, the back side of it is padded with a fairly thick rubber...Did Mini replace the little bump stop with rubber lining behind the carpet? It must be. If that's the case, I can just stick a 3/4 inch piece of hard rubber right behind where the pedal hits and call it a mod. Any comments?
Old Feb 12, 2014 | 03:12 AM
nine5raptor's Avatar
nine5raptor
My 2010S had the little rubber plug. And the carpet did not go up where the plug was. It is higher up in the footwell than I expected based on previous cars.
Sent from my XT926 using NAMotoring
Old Feb 12, 2014 | 05:56 AM
Aikmanson's Avatar
Aikmanson
Agreed on my 2010 S there was a rubber plug to pull out and put the new clutch stop in. The carpet does not go up to where the pedal meets the stop. I don't see why yours would have the carpet go up much higher unless it was previously modified that way?
Are you the original owner?
Old Feb 12, 2014 | 07:41 AM
stronzo2's Avatar
stronzo2
No, I am not the original owner and the carpet is stock, no modifications.
I'll have to look again but I can't imagine finding anything. The pedal arm is the only part of the pedal hitting the carpet, I do not see it hitting anything else higher up. Thanks for the reply.
patsum
26
May 29, 2021 06:29 PM
thadscottmoore
Sep 25, 2015 10:07 AM
Quixotic1
Sep 11, 2015 11:15 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
