R56 Battery Tender Harness Install Question
Old Feb 8, 2014 | 06:49 PM
cactusjk's Avatar
cactusjk
I want to install a Battery Tender harness on my 2013 R56 Hardtop. The problem is the negative terminal nut does not come off due to a retainer.
Is there a clean way to install ring terminals on OEM battery terminals?
Old Feb 9, 2014 | 06:11 AM
minsanity's Avatar
minsanity
Sandwich the ring w/ another nut.
Old Feb 9, 2014 | 06:46 AM
sbninja's Avatar
sbninja
I'm not following What do you mean, does not come off?
How would you change the battery then?
Old Feb 9, 2014 | 08:03 AM
cactusjk's Avatar
cactusjk
The nut that tightens the negative terminal on is designed to not completely back off the stud so you don't lose it. The stud thread ends are flared. This will also prevent threading a new nut on to "sandwich" the ring terminal.
Old Feb 9, 2014 | 08:28 AM
MiniPitCrew's Avatar
MiniPitCrew
Cut out a portion of the ring terminal so that it resembles more of a spade terminal. Then you can back off the battery terminal nut a bit, slide the quasi-spade terminal in place, and then tighten the battery terminal nut back down.
Old Feb 9, 2014 | 08:30 AM
cactusjk's Avatar
cactusjk
I was starting to think that is a good way to do it.
Old Feb 9, 2014 | 09:43 AM
sbninja's Avatar
sbninja
Now I see what you mean, I just looked at my 2013 coupe. .
As posted, just cut off a little from the ring and slip it in. Or cut off the battery tender connector completely and buy a new type connector and crimp on.
W0TM8
Dec 19, 2019 07:50 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
squawSkiBum
Oct 2, 2015 09:21 AM
nismo4life
Aug 5, 2015 08:31 AM
