R56 Oil Catch Can???
Old Feb 5, 2014 | 11:32 AM
Whitt's Avatar
Whitt
From: From Michigan, United States, Currently living in Germany
Oil Catch Can???
Hi Everybody,
So, Ive been hearing a good bit about "Oil Catch Cans" i get what they do, but would anyone recommend them? Are they useful? especially for the R56's because of their oil consumption i thought it'd be a good investment. If you guys can fill me in and give me some info on them and the installation process, cost,good ones to buy, info about them..etc... That'd be much appreciated!
Thanks!!
Old Feb 5, 2014 | 12:15 PM
Ian Landesman's Avatar
Ian Landesman
You can use an OCC to 'catch' vapors from your PCV system before reentering your intake just before the turbo and just before the intake manifold. I have an OCC on my driver' side and have NOT blocked the passenger side. An OCC costs a little money, and in my eyes, can't hurt if you are emptying it when you change oil. Blocking off the passenger side causes the vapors to go through your OCC during not only boost, but also vacuum. I am not convinced it's a good idea to block after reading through the threads about oil consumption via an internal oil leak some report.
What brand are you interested in? I have the BSH from WMW.
Old Feb 5, 2014 | 02:31 PM
Whitt's Avatar
Whitt
Well Ian, I'm not really sure what an OCC is, I've never owned a turbo'd car before, nor one that uses so much oil. I knw that the R56's burn a good amount of oil, thats why i was looking into the oil catch can. Other than that, I'm pretty unsure, so when you refer to an OCC I'm still unsure on what you mean, obviously its something that will catch oil vapors or something along the lines of a PCV valve. And as far as brands go..im just as clueless, thanks for the response and i look forward to hearing from you.
~stay mini~
Old Feb 5, 2014 | 02:56 PM
aldito2's Avatar
aldito2
I use mine, but I think it's more gimmick than anything. I dunno. If I could go back, I wouldn't buy it again. My $0.02. (I have the BSH one)
Old Feb 5, 2014 | 05:59 PM
DneprDave's Avatar
DneprDave
I have a BSH Oil Catch Can with the passenger side PCV hose blocked off. My MINI barely consumes any oil.
The main purpose for an OIL Catch Can is to reduce carbon build up on the intake valves on the direct injected N14 engined Cooper S. The non-S cars have port injection and don't have a carbon build up problem. N18 engines, 2011 and later, also don't need an Oil Catch Can, as they have an improved head design that reduces intake valve carbon build up.
Dave
Old Feb 5, 2014 | 06:04 PM
aldito2's Avatar
aldito2
Maybe I have a good mini lol. Mine never consumed oil and I'm only able to empty my occ once every one month in the winter and 6 months in warm weather. Even when I empty it it's never more than 25% full. I'm willing to sell my occ if anyone wants it (OP?) I'll include the PVC blockers too (brand new never uses)
Old Feb 6, 2014 | 03:16 AM
Whitt's Avatar
Whitt
Okay great, thanks for the info. I guess ill just hold off on it unless i find a cheap one. I really don't know what they run. I was just curious cause of how much oil the R56's use. Thanks guys!
Old Feb 6, 2014 | 05:55 AM
Ian Landesman
It can't hurt, but definitely do your research first. There are a lot of threads on here about it. Read the ones about reported increased oil consumption after blocking the passenger side PCV in particular. Could be idiots forgetting to empty their OCCs until they overflow OR could be a pressure issue in the PCV system when blocked off that causes oil to be redirected into the combustion track at some point. I don't know, and I'm not going to risk it, so I don't have it blocked, but I also drive a LOT of highway so my engine is less likely to get carbon than a 5 minute around town driver.
Even with an OCC, if you are not driving extensive highway miles, plan on having a carbon cleaning every 30-50K. Lots of threads on here about DIY methods with plenty of pictures of carbon buildup, or you can pay someone $500-$300 to do it for you.
Stand on the shoulders of giants... I have an OCC, but am basing most of my opinion on what others have said alongside their photos.
Old Feb 6, 2014 | 06:50 AM
zrickety's Avatar
zrickety
FWIW, I have been researching catch cans for my VW and even had my PCV setup for VTA (vent to atomosphere). I thought this would reduce buildup on the valves and manifold, but the truth is 2 years later it's made little to no difference. Just made the car smell a bit. Direct injection is dirty by design, your best bet is just a manual cleaning some time. I'd say 60k-80k if it's running ok.
Old Feb 6, 2014 | 07:36 AM
Whitt's Avatar
Whitt
Okay great, Thanks guys, i really appreciate it. Ill continue to do research on them. As far as carbon cleaning, how hard/big of a job is it? i bought mine used and has over 100k kilometers, i doubt its ever been cleaned and I've heard a lot about the cleanings.
Old Feb 6, 2014 | 08:01 AM
zrickety's Avatar
zrickety
Supposedly, you can drive the car hard (above 3000rpm for 20-30min) and it will burn off most deposits. The 'Italian tune-up.' That said, a manual cleaning involves removing the intake manifold. I would say it's more tedious than hard. Here is one thread
https://www.northamericanmotoring.co...-cleaning.html
Old Feb 6, 2014 | 09:51 AM
SoCal MCS's Avatar
SoCal MCS
I have a BSH OCC and PCV Block that I installed after I had the walnut blast 15K miles ago...I used to burn about a quart every 5K miles (I change oil every 5K) but over the last 3 oil changes I use less than 1/4 quart/5K. I just changed oil this past week and pulled the intake off and used a lighted bore scope to take a peek at the valves...no buildup to speak of. When I did the walnut blast at 38K it was absolutely horrible! Big chunks of carbon buildup...I was surprised the valves even closed!
So...in my book the OCC and block is worth every penny....but I'll pull the intake again in 15K to take another peek.
Old Feb 6, 2014 | 10:38 AM
Ian Landesman
I'd like to know how it looks when you pull it again.
Sounds like everyone is saying, 'Here's my opinion, but I don't rightly know for sure.' Socal will 'know' after he pulls his intake, but I'd say block at your own risk, and don't forget to empty the thing. =)
Old Feb 6, 2014 | 10:48 AM
aldito2's Avatar
aldito2
occ reviews are so mixed. It's odd. I can't see it hurting but I also don't think it helped me
Old Feb 6, 2014 | 11:18 AM
minibx's Avatar
minibx
Originally Posted by Whitt
Well Ian, I'm not really sure what an OCC is, I've never owned a turbo'd car before, nor one that uses so much oil. I knw that the R56's burn a good amount of oil, thats why i was looking into the oil catch can. Other than that, I'm pretty unsure, so when you refer to an OCC I'm still unsure on what you mean, obviously its something that will catch oil vapors or something along the lines of a PCV valve. And as far as brands go..im just as clueless, thanks for the response and i look forward to hearing from you. ~stay mini~
I guess that by now you what OCC means right? Some people swear by the oil catch can (OCC) others don't believe in it, in my opinion they are too expensive and some people like them for looks. Others have homemade OCC's etc..my guess is that it helps some engines but not all.... Then again I'm just guessing lol
Old Feb 6, 2014 | 11:24 AM
bimpower's Avatar
bimpower
I have one for sale if anyone is interested.
https://www.northamericanmotoring.co...boost-tap.html
Old Feb 9, 2014 | 01:18 PM
Whitt's Avatar
Whitt
ahh okay, Great! thanks for the help!!
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
