R56 Popping out of 1st gear
Old Jan 30, 2014 | 02:30 PM
Astrobl4ck's Avatar
Astrobl4ck
Have a 2007 stick shift Mini Cooper S and ever since I bought it I've noticed every once in a while I'll put it into 1st and start to let off the clutch and give it gas and all of a sudden it pops out, sometime it's so powerful it pops all the way out of gear and sometimes it pops out and starts grinding. It has gotten really annoying so does anyone have any ideas on why this is happening?
Old Jan 30, 2014 | 03:30 PM
Slave to Felines's Avatar
Slave to Felines
I hope I'm wrong, but in other (old) cars I would say this is a symptom of a transmission needing a rebuild.
Worth changing the fluid and looking for chunks or lots of glitter in what comes out. Who knows, it may help with the shifting, too!
Old Jan 30, 2014 | 05:45 PM
RAYGUNZAP's Avatar
RAYGUNZAP
I have a 2013 MCS, and occasionally, I've experienced the same thing, but in 6th gear. It happens when I'm shifting, pushing 3500/4000 R's. It's disconcerting.
Old Jan 30, 2014 | 07:12 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Usually when this happens it could be either a linkage issue or the transmission is going out/needing rebuild. Sometimes if you drain the fluid in the trans. you can see if there is anything serious going on by looking at the fluid for metal type shavings. Usually there will be excessive amount. these are just a few things it could possible be. Not at all saying this is it. good luck!
Old Jan 31, 2014 | 06:08 AM
v10climber's Avatar
v10climber
Syncros are likely going bad. Change the trans fluid and that might help.
Old Jan 31, 2014 | 07:50 AM
psichick's Avatar
psichick
this.
but changing the fluid isn't going to do anything if the gear is stripped. find a good tranny shop.
Old Jan 31, 2014 | 09:18 AM
JcarrollWS6's Avatar
JcarrollWS6
The bearings are worn allowing slop in the shafts, and the torque from the gears engaging just pushes them out of engagement. You need a complete rebuild or a new transmission.
Changing the fluid will be an unneccessary cost, I am afraid.
Are you the original owner? How many miles?
Old Jan 31, 2014 | 09:29 AM
Astrobl4ck's Avatar
Astrobl4ck
Originally Posted by JcarrollWS6
The bearings are worn allowing slop in the shafts, and the torque from the gears engaging just pushes them out of engagement. You need a complete rebuild or a new transmission. Changing the fluid will be an unneccessary cost, I am afraid. Are you the original owner? How many miles?
I'm the 2nd owner and it has 46k on it
Old Jan 31, 2014 | 12:02 PM
JcarrollWS6
Somebody must have been hard on the car, or not let it warm up properly.
Old Jan 31, 2014 | 12:12 PM
v10climber's Avatar
v10climber
I've not seen or heard of anyone who has either rebuilt their trans or had one rebuilt. I think the only real options at the moment are new or used ones out of a wrecked car. Its not a crazy complicated process so a good trans shop could probably source the parts but I don't know that there are published specs for things like clearances which you would need for the rebuild
Sent from my Nexus 10 using NAMotoring
Old Jan 31, 2014 | 03:22 PM
Astrobl4ck's Avatar
Astrobl4ck
Update: now it's popping out almost every single time as soon as I get to like 2k rooms and I'm taking it in to the dealer either tonight or tomorrow
Old Jan 31, 2014 | 03:48 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I have a funny feeling that your transmission is on its way out! But its strange that is happening at 46k.. Keep us posted. good luck.
rob&JCW
Feb 21, 2018 02:41 PM
embiggenedmini
Oct 15, 2015 12:36 PM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Sep 3, 2015 02:06 PM
