R60 Engine Temp/Oil Pressure Guages
Old Jan 28, 2014 | 08:58 PM
jkc1985's Avatar
jkc1985
Hey All!
New to mini's and my wife just for a 2014 countryman. We are in the process of getting used to all of minis quirky features.
Is there a way to see the engine temp and oil pressure on the mini? Most cars come with these gauges, but mini's do not.
Thanks!
Old Jan 28, 2014 | 10:26 PM
CN R60's Avatar
CN R60
For oil pressure I believe you have to install a mechanical gauge for this.
For oil temperature, you can install a mechanical gauge or you can get a ScanGauge II which hooks into the OBDII interface provided that it has Mini-specific programming (http://www.scangauge.com/support/x-gauge/mini/). I'm glad I looked this up as non of the other OBDII solutions I looked at previously could provide oil pressure info for the Mini. With an electronic gauge you will also have access to other info such as coolant temp, IAT, boost, etc. so it may still be useful to invest in one even if you decide to go with a mechanical gauge for the oil temperature.
Old Jan 29, 2014 | 01:59 AM
SODA66's Avatar
SODA66
Temp gauge
Mini has an accessory one or two gauge set that the dealer can install on a Mini. I know one is water temp gauge, but it is in C not F and the other is either a g meter or something. I see no need for the g meter in mine but I am thinking about having a water temp gauge installed at the dealer.
be advised these gauges are in the JCW accessories and the gauges have black face.
I have seen recent post on this site about this so do a search. I remember reading about a guy who put them on his country man.
Old Jan 29, 2014 | 04:23 AM
MyroMini's Avatar
MyroMini
CravenSpeed as a new product, nGauge, that plugs right into the OBDII port
http://www.cravenspeed.com/ngauge/
Or you can go the traditional way, with sensors, wires, etc
http://www.cravenspeed.com/mini-complete-gauge-kit/
Old Jan 29, 2014 | 04:46 AM
carboman's Avatar
carboman
Oil pressure is via mechanical connection only. I have a scan gage II and it allows me to monitor 4 things at once like engine temp, intake temp, boost pressure, volts and so on. Took 5 mins to install and works great.
Seemed like the best bang for the buck at around $150
Old Jan 29, 2014 | 12:10 PM
hoonu's Avatar
hoonu
Thanks for the link to the nGauge. I like the reversible nature of those, and the bracket certainly looks clean.
Old Jan 29, 2014 | 12:26 PM
ZaliZoe's Avatar
ZaliZoe
With mini connected u can check engine temperarure. With the driving excitement app.
Old Jan 29, 2014 | 12:29 PM
hoonu's Avatar
hoonu
Mebbe so, but I don't want intervening steps (button pushes or whatever) in between me and the data.
Old Jan 29, 2014 | 05:27 PM
opwei's Avatar
opwei
you might want to check out this link about unlocking hidden data
Old Jan 30, 2014 | 08:10 PM
hoonu's Avatar
hoonu
That's kinda neat, but again, not real-time, real world.
Saving mah pennies for the nGauge.
Old Jan 31, 2014 | 04:44 AM
mini_z's Avatar
mini_z
Old Jan 31, 2014 | 06:13 AM
cactusjk's Avatar
cactusjk
Cravenspeed nGauge is a great way to go!
Old Feb 10, 2014 | 12:01 PM
R60mini's Avatar
R60mini
An economical method to monitor engine readouts is thru the OBD with wifi dongle plugged into OBD port and accessed thru smart phone app. There is a discussion in electrical about this. Was $10 for dash command app and $25 for the "ELM" wifi, works great, but will not give oil pressure info.
TREX
Nov 2, 2019 07:31 PM
blackie
Jan 18, 2017 09:56 PM
David.R53
Sep 1, 2015 06:49 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
