R56 3rd time my turn signal indicator has fallen off
The right indicator in the plastic housing between the right front wheel and the door. It comes flying off when I'm driving down the interstate, usually when the weather is cold. Multiple dealer visits. Super frustrating.
The first time I was able to stop quickly and shove the housing back into the hole, but on subsequent occasions it has flown off, ripping the electrical wires with it.
If it's properly installed, I don't believe it can come off with the hood down. It's held in place by 4 plastic doglegs on the back side. The scuttle has to move forward to come off and the hood is in the way when it's closed. I suspect your scuttle was improperly installed and being held on by only the front or back clips, not both. It's possible to install it incorrectly and still look like it's secure. The only way to be sure is to peer up ito the fenderwhell and insure all 4 clips are engaged. Take a look at a removed scuttle and you'll see what I mean.
09R56
Nov 16, 2022 10:49 AM
Dec 23, 2015 10:36 AM
nismo4life
Aug 5, 2015 08:31 AM
