R56 Minor mods that make a difference?
Old Jan 22, 2014 | 01:04 PM
iMike's Avatar
iMike
Have been reading this site a fair bit as I'm picking up an '08 S tomorrow.
One thing that I've decided to do right away is to install these torque arm bushings. The feedback on this kit is that it makes shifts crisper and reduces torque steer. And it's $60 and a quick DIY install.
Are there other minor mods that should be done to these cars? Things along the lines of the mod above: cheap and simple, but makes a difference in the driving experience.
Old Jan 22, 2014 | 02:20 PM
devicemanager's Avatar
devicemanager
<deleted link to JB+ thread>
My bad. Yes, the JB+ is for the N18 and you have the N14. Sorry about that....
I've read good things about the Alta accessport.
Old Jan 22, 2014 | 02:31 PM
iMike's Avatar
iMike
JB+ is not for the N14, is it?
Old Jan 22, 2014 | 02:46 PM
JcarrollWS6's Avatar
JcarrollWS6
BMS's clutch stop. Absolutely essential and under $10.
Old Jan 22, 2014 | 02:49 PM
Aikmanson's Avatar
Aikmanson
I second this. Love mine, that alone with a scangauge and CS dipstick are the extent of my mods. All useful IMO, although the CS dipstick is pricey.
Old Jan 22, 2014 | 04:28 PM
automan21's Avatar
automan21
Whats this thing you speak of?
Old Jan 22, 2014 | 04:33 PM
hokusai's Avatar
hokusai
This:
http://burgertuning.com/clutch_stop_mini_cooper.html
Old Jan 22, 2014 | 04:38 PM
automan21's Avatar
automan21
Oh I see, thanks.
Old Jan 22, 2014 | 04:41 PM
ra2fanatic's Avatar
ra2fanatic
Minor mods....hm....NM's charge and discharge pipes can be beneficial. They're pricey for tubes, but worth it I think.
Old Jan 22, 2014 | 04:54 PM
vetsvette's Avatar
vetsvette
Moderator
Just ordered the clutch stop myself. Definitely recommend the Cravenspeed dipstick. It is a little expensive, but I get a better read on my oil level than with the stock unit. Letting your Mini get low on oil is not a good thing.
Old Jan 22, 2014 | 05:28 PM
R56BrgMcs's Avatar
R56BrgMcs
Torque arm inserts make a big difference. Also whole reading this I ordered the BMS clutch stop.
Old Jan 22, 2014 | 05:34 PM
R56BrgMcs's Avatar
R56BrgMcs
Also, you could order the m7 strut tower defenders, these are more a preventive thing and you can buy the additional strut tower piece later.
Old Jan 22, 2014 | 06:02 PM
Aikmanson's Avatar
Aikmanson
Glad to see people gettin the clutch stop, great cheap mod. Torque arm inserts are next on my list as well.
Old Jan 22, 2014 | 06:04 PM
JcarrollWS6
Good for you R56Brg. It makes a huge difference.
I would buy the best tires for what you are doing with the car before bothering with any other suspension work. All that will do is add weight. Strut bars are ok, I suppose. Lighter wheels, JB+ Is the only power mod truly worth it at low cost. Better brake pads, and a lot of seat time.
Old Jan 22, 2014 | 06:32 PM
vetsvette's Avatar
vetsvette
Moderator
JB+ is not an option. He has a N14.
Old Jan 22, 2014 | 06:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You got it right with the Torque Arm Bushing being number #1
But the Light in Sight is another good mod, especially if your taller.
Scangauge
is great to monitor everything
NM short shifter, cheap and really improves the shifter feel
and a short antenna really improves the look.
Old Jan 22, 2014 | 07:04 PM
JcarrollWS6
Well then no power modifications. Continue with the remainder of the list. My bad.
Old Jan 22, 2014 | 09:53 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
22mm rear sway bar.
Old Jan 23, 2014 | 05:48 AM
RockAZ's Avatar
RockAZ
Glad you mentioned the clutch stop, I had come across a mention of it in the forums last summer when I bought the Mini used and dismissed it as silly without putting any thought into it. Now a clutch fluid replacement and almost 10k miles later I get what it does and ordered one last night. Thanks again for mentioning BMS, looking forward to having it.
Also, the torque arm insert was the first mod I did, major difference, a really big impact on getting the power to the road - highly recommend.
Old Jan 23, 2014 | 07:33 AM
vetsvette's Avatar
vetsvette
Moderator
I'm ordering the torque arm insert as soon as I can get a look at what type I have. Keep forgetting about it when it's on the lift.
Old Jan 23, 2014 | 07:58 AM
JcarrollWS6
Is your car that close to the build date switch out, vette? If that's the case, post build date and shape of bushing used.
Old Jan 23, 2014 | 08:02 AM
JcarrollWS6
For sure man. The new ones are ahipped with four (4) thinner shims, I removed 1 and that is the equivalent of the old 2 shims. So three is the new two if that makes sense. Some people had trouble with the clutch interlock not kicking in at start up, but I never noticed anything with 3. It's just right. Takes out lots of slop in the clutch throw. Reminds me now of the good old aftermarket clutches, albeit with a very comfortable peddle effort. Takes about 10 min to forget how the clutch used to be.
Old Jan 23, 2014 | 08:36 AM
CooperJCW's Avatar
CooperJCW
I have a 2013 R56 JCW. Do all models benefit from replacing the Torque Arm Bushing? Its hard to tell what Mini improves with each model year.
Old Jan 23, 2014 | 08:45 AM
RockAZ's Avatar
RockAZ
Probably not in a JCW, but have someone rev it a few times while you watch to see how much the engine block moves, or "torques". I would say more than an inch movement and you should at least try a torque insert if you have a manual shift.
Old Jan 23, 2014 | 09:03 AM
JcarrollWS6
I just checked the mini part numbers. Not only is it the same for JCW and S, the part number is shared by all coopers 2008-2012. (2007 in some applications such as justas and 07 JCW). All motor mounts are shared based on engine block, without regard to torque output.
So, yes. It will indeed help.
