yellow half full cel with weird idle
Old Jan 10, 2014 | 07:52 AM
07MiniCopperS's Avatar
07MiniCopperS
I started my car this morning and a half full check engine light came on as well as a little tachomter symbol with an arrow pointing to it. The car idles between 1000-1500 rpm and fluctuates. Anyone know what's up as I haven't pulled the code yet and mini can't get me in until next Tuesday.
Old Jan 10, 2014 | 08:05 AM
f0rgetme08's Avatar
f0rgetme08
Same thing happened to me a this week. It came on in the morning then go away later on in the day. The link below is what I went thru. Have your local dealer check it and hopefully you have a trust worthy one near you. Good luck!
https://www.northamericanmotoring.co...tting-old.html
Old Jan 10, 2014 | 12:53 PM
kacken's Avatar
kacken
I'm assuming you have an 07 Cooper S with your user name. I had the same issue with mine. It could be due to cold weather, in which moisture is making its way from the intake to the throttle body and freezing the motor. You may need the updated intake installed to avoid this issue. The dealer split the cost with me due to it being a known issue.
I hope this helps!
Old Jan 10, 2014 | 01:23 PM
oldtruckpainter's Avatar
oldtruckpainter
I had the same thing on mine. The new version of the intake took care of it.
actualsize37
Nov 18, 2015 08:58 AM
dropnstylez
Oct 29, 2015 08:57 AM
molala
Oct 2, 2015 01:53 PM
zr0z
Sep 3, 2015 04:50 PM
Ntety
Sep 2, 2015 08:39 PM
