R52 Front Control Arm/ Brake Bushings and Alignment
Old Jan 7, 2014 | 09:16 AM
VictoriaH's Avatar
VictoriaH
I was told two different things:I need an alignment after replacing the control arm bushings and that I don't. They are also called brake reaction bushings. Any opinions on this? I won't have to pay for the alignment, but this is more about who to believe. Right now, I'm not trusting either.
Old Jan 7, 2014 | 10:01 AM
v10climber's Avatar
v10climber
They're both right. It kind of depends. If the alignment was done previously with bad control arm bushings the bushings can deflect and mess up the alignment. Now that you've got new bushings in the car what was a good alignment may not be good anymore because the bushings are not deflecting. Also, the subframe has a little play in the bolt holes so there is some possibility for changing alignments when the subframe is loosened to get the bushings out. If the alignment is free it certainly wouldn't hurt to have it done.
W0TM8
Dec 19, 2019 07:50 AM
FLYM1N1
Aug 15, 2015 11:20 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
