R56 How to Put Automatic into Neutral with Engine OFF ?
Old Jan 6, 2014 | 04:48 PM
metro62's Avatar
metro62
OK, this sounds like dumbest of dumb questions, but is it possible to put the automatic transmission into neutral with the engine off?? Owners manual says it will shift with 'engine running' or 'ignition on'.
It is close to -20 degrees F here and I wanted to push the car into the garage to swap the dead battery. I inserted the key, and held it in, but no luck in putting the transmission into neutral. I tried a couple different times, but no joy. Perhaps something is frozen up? This should be a lot easier.
2007 MCS with automatic transmission
Old Jan 6, 2014 | 04:54 PM
Tylerlanger1's Avatar
Tylerlanger1
you should beable to shift it to neutral if the key is in ignition is on and your foot is on the brake. if that doesnt work then pull the shift boot off and you will see a yellow loop. pull up on the loop with something like a pick or a pliers and you should be able to put it in neutral
Old Jan 6, 2014 | 05:10 PM
cerenkov's Avatar
cerenkov
I believe that there is a physical override underneath the collar.
Old Jan 6, 2014 | 07:13 PM
Subzero's Avatar
Subzero
Insert fob
Push start button with foot *off* of the brake
Shift into neutral
Old Jan 6, 2014 | 07:29 PM
metro62's Avatar
metro62
Thanks, that worked. I had to push the brake really hard in this cold to release the shifter.
Old Jan 6, 2014 | 07:30 PM
Brchopper's Avatar
Brchopper
It might not go to neutral because your battery is dead. Hook some jumper to your new battery and to your car like you were going to jump it. Now try to put it in neutral. The car needs powerto go to neutral.
vetsvette's Avatar
vetsvette
Moderator
Originally Posted by Subzero
Insert fob
Shift into neutral
He said he has a dead battery.
09R56
Nov 16, 2022 10:49 AM
Lex2008
Aug 16, 2015 08:33 PM
ki7hy
Aug 12, 2015 07:07 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
