Care and Feeding of Timing Chain
Old Dec 29, 2013 | 11:52 AM
cjny's Avatar
cjny
My 2010 MCS has 42k mi's and I'm committed to keeping it for the long haul. What is the consensus on taking care of the timing chain? Is there a maintenance / inspection routine that can minimize the chance of serious problems or catch things before major repairs are necessary?
The dealer proactively installed the new timing chain tensioner under warranty shortly after I bought the car in 2010. There were no symptoms at that time. Occasionally these days I hear some of the rattling sound when the engine is cold but not on every start-up and never for more than 10-20 seconds. They recently checked the chain tension and said it was OK, whatever that means.
Keeping oil topped off goes without saying. I'm also very careful about driving gently until the engine warms up. I'm considering adding an oil pan heater for use in colder weather.
Would keeping an eye on the chain tension make sense? How often? What measurement would trigger replacement? Is measuring chain tension a DIY?
Any other suggestions?
Old Dec 29, 2013 | 02:18 PM
ashchuckton's Avatar
ashchuckton
If your MINI is rattling for 10-20 seconds on start up I'd say it is time to look now. Possibly your tensioner is going bad again. I read somewhere that MINI was replacing timing chains on these engines as a warranty thing. You might want to search that out.
Old Dec 29, 2013 | 02:36 PM
vetsvette's Avatar
vetsvette
Moderator
Sounds like you are doing everything that you can do to maintain your chain assembly. IIRC anything over 68mm of slack is considered excessive. The "new" tensioner your dealer installed may not be the latest "improved" part. The timing chain campaign/recall effects the '07-'10 MCS.
Ian Landesman's Avatar
Ian Landesman
If it rattles for 10 seconds don't be nervous. 1 minute? Bring it in.
Old Dec 29, 2013 | 04:48 PM
cjny's Avatar
cjny
Thanks for the input.
Google search turned up this document which describes measuring the timing chain slack.
Old Dec 29, 2013 | 05:06 PM
cjny's Avatar
cjny
I had the car at the dealer recently. Unfortunately they were unable to reproduce the noise. (It happens less than half the time.) They said I have the latest tensioner and, with slack within acceptable limits, that means no need to change parts.
Changing the tensioner seems pretty easy. Do we know if the new part weakens with age, so that replacing it after a while might make sense?
Old Dec 29, 2013 | 05:27 PM
Ian Landesman
Originally Posted by cjny
Thanks for the input. Google search turned up this document which describes measuring the timing chain slack.
Nice! They should sticky this document.
Old Jan 1, 2014 | 04:04 PM
rob99281's Avatar
rob99281
you might think its an easy check but you need the precise factory instructions, and a crank pin..if it was my car i would have the newest tensioner installed, and oil level check like you said, or buy an n18
Old Jan 1, 2014 | 05:20 PM
vetsvette's Avatar
vetsvette
Moderator
I just got my car back from the dealer yesterday. Timing chain backlash measured 70.9mm so they replaced the timing chain cassette, crank & cam bolts, and valve cover gasket. Sounds like a new motor now. I never really noticed a problem before this, other than the occasional clatter on cold start. I change my oil (Mobil 1 0W40) every 5K max, and check my oil level at least once a week. If your car falls under the recall/campaign I recommend you get it checked out whether you have the "death rattle" or not.
Old Jan 1, 2014 | 08:15 PM
CA94960's Avatar
CA94960
How much did that cost you?
Old Jan 1, 2014 | 08:30 PM
zrickety's Avatar
zrickety
Sounds like it was covered under the campaign/recall?
Old Jan 1, 2014 | 08:41 PM
vetsvette's Avatar
vetsvette
Moderator
Zip, zero, nada, nuthin'. Covered by the campaign. Even had a '14 Countryman S loaner from Friday until Tuesday.
Old Jan 1, 2014 | 09:50 PM
scott13's Avatar
scott13
I am glad that MINI took care of your car and it is running great now!
Old Jan 2, 2014 | 08:45 AM
CA94960's Avatar
CA94960
That's great! I saw you owned a 2007 with over 100,000 miles - I had no idea they would cover a car that was out of warranty with that many miles.
Old Jan 2, 2014 | 09:26 AM
vetsvette's Avatar
vetsvette
Moderator
I was surprised also. My jaw really dropped when he offered the new loaner and complemented me on how well my car had been maintained.
Old Jan 2, 2014 | 09:51 AM
TREX's Avatar
TREX
Maybe Mini Cooper is realy serious about trying to repair their soiled reliability image by finally standing behind their product.
While this is long past due, it is great news for current and potential new Mini Cooper owners.
Now if only BMW would adapt the same strategy of standing behind their line of cars, who knows, I might even be tempted to buy one to go with our Mini.
Old May 15, 2014 | 12:18 PM
TorchMINI's Avatar
TorchMINI
I'm having my timing chain tension measured as a baseline voluntary project. Does anyone know what a reasonable fee would be from a MINI dealership for just this?
Old May 16, 2014 | 06:51 PM
Ian Fraser's Avatar
Ian Fraser
Mine is in being done now. 2012 JCW.
Old May 16, 2014 | 07:43 PM
TorchMINI's Avatar
TorchMINI
Ian,
What did it cost?
I am quoted $250 for chain tension check and tensioner bolt - (adjust or replace).
Old May 16, 2014 | 09:48 PM
Ian Fraser's Avatar
Ian Fraser
Originally Posted by TorchMINI
Ian,
What did it cost?
My car is still under warranty
Old Dec 14, 2015 | 03:03 PM
cjny's Avatar
cjny
An update on this: The rattling on cold start-ups for my 2010 MCS had gotten progressively worse in the 1.5 years since starting this thread so I finally took it in to the dealer again. At that point it would rattle more often than not when starting a cold engine and it took longer and longer to go away. I asked them to check the chain tension, which they did.
The slack in the chain measured 70 mm so I was surprised when they suggested changing the tensioner. The tech described the old one as "squishy". My understanding was that there was a service bulletin saying to change the entire chain assembly if the measurement was 68 mm or more. The shop foreman,though, claims that TSB does not apply to the VIN range that includes my 2010 MCS. He says there is no official limit for the chain measurement on my car.
Has anyone else heard this?
I had them install the new tensioner and the car is very quiet now. Presumably I am just kicking the can down the road and will eventually be forced to change the chain but for now the quiet is comforting.
Old Dec 14, 2015 | 04:16 PM
TREX's Avatar
TREX
Probably are, it's just a matter of time.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
makg
Aug 21, 2015 02:49 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
