R50/53 Replaced Clutch, Mushy clutch pedal.
Old Dec 24, 2013 | 06:48 PM
Tab32's Avatar
Tab32
I replaced the clutch over the weekend and now the clutch pedal only engages at about 1/4 way. It will go into gear just fine, but it is just so soft and feels like a honda now
When I took off the slave cylinder, the cylinder extended out more. I'm thinking that I was supposed to compress the cylinder as I removed it, and now there is air in the Hydraulic line.
What do you guys think? Do I need to replace the slave cylinder or just bleed out the air with the clutch down over night trick?
Old Dec 25, 2013 | 12:09 AM
PrplPplEtr's Avatar
PrplPplEtr
Pedal down bleed worked for me.
Sent from my Galaxy Nexus using NAMotoring
Old Dec 25, 2013 | 03:46 PM
oddcarnut's Avatar
oddcarnut
Try compressing the slave cylinder and rebleeding. Worked on our car when I did a clutch change.
Old Dec 27, 2013 | 06:32 PM
Tab32's Avatar
Tab32
Yeah, I'm gonna wait till it gets a little warmer to do the bleed unless I find another garage.
Old Dec 27, 2013 | 08:54 PM
PrplPplEtr's Avatar
PrplPplEtr
2' length 2x4 holding the pedal down overnight (jammed in place with the seat), tomorrow no more mush, weather be damned.
Old Dec 28, 2013 | 03:37 PM
Stoker's Avatar
Stoker
Your saying, doing what you suggest will get rid of the air in the system?
Old Dec 28, 2013 | 09:08 PM
GreekDrifter91's Avatar
GreekDrifter91
wait teddy you removed the slave cylinder from the hard line when i told you not to lol?
Old Dec 28, 2013 | 11:37 PM
Debi's Coop S's Avatar
Debi's Coop S
This will require a lot of bleeding.
Finhead
105
Aug 14, 2023 07:51 AM
eliseo1981
Jan 28, 2021 02:45 PM
PrimePower
Aug 16, 2015 06:29 PM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
