Brake line confusion - R53 upgrade to R56 (R53 JCW)
Old Dec 24, 2013 | 04:24 PM
Sin MINI's Avatar
Sin MINI
I have a late model 2006 R53 (not late enough however to get the JCW brakes fitted as stock ). Decided to upgrade my front brakes and found the most cost effective solution was to get cast-off R56 brakes since they are the same as the R53 JCW brakes. Found used front calipers with the stock rubber brake line and heat shields, barely-used rotors, new pads, and a set of braided lines (4...Figure if I'm gonna have to bleed my brakes, might as well do all four corners). Went on on a short vacation and dropped my car off at my mechanic with the parts. Here's where the upgrade went south.
Mechanic called and said the brakes lines don't fit with the new calipers. They work with the stock brakes (all four corners), but not the R56 calipers. One pair of the lines has banjo fittings for the caliper end but the R56 calipers do not take a banjo fitting; the rubber lines are threaded on both ends (pictures below). I have to ask my mechanic again, but I thought he also said that the rubber lines didn't fit my car either...that part doesn't make sense to me as it appears to be identical to the non-banjo fitting on the braided lines.
If anyone has any ideas I'm listening. If anyone has pictures or web links that show what I really need (if in fact these are not correct) I would be grateful.
PS: Found a tutorial on Pelican that implies banjo fittings on all four stock R53 brakes. Is that true? If so, then it looks to me that these lines should be correct, assuming that the short lines are for the front.
Thanks!
Caliper with rubber line twisted around so free end is visible
Lines. Two short ones do NOT have the banjo fittings; two longer ones do. I don't know which are for the front or for the back (the rubbers lines aren't the same length as either of the braided pair)
minimofo
Apr 4, 2016 07:36 PM
Zettinger
Aug 25, 2015 04:04 PM
StealthR53
Aug 8, 2015 10:59 AM
marendt428
Aug 8, 2015 04:44 AM
