R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 Keyfob Range
Old Dec 16, 2013 | 10:50 AM
RavenGirl's Avatar
RavenGirl
Keyfob Range
I've had my Paceman for a few weeks, and in general I'm happy. The one complaint I have right now is the weak keyfob range I seem to have. In my vw rabbit I could be several feet away to lock or unlock the car. It seems with the paceman I have to be right next to it. I've also noticed that sometimes the button lock on the door handle work, sometimes it doesn't. Yes, I've changed the battery in the fob. Have the same issue with both keys. Is this normal, or is something wrong?
Old Dec 16, 2013 | 04:56 PM
ddminikc's Avatar
ddminikc
Our '09 Clubman is the same. We have maximum 3 foot range on the key fob even with a new battery.
Old Dec 16, 2013 | 05:25 PM
DneprDave's Avatar
DneprDave
Gosh, The range is about fifty feet on my 2010 Clubman!
I don't have the convenience package.
Dave
Old Dec 16, 2013 | 05:46 PM
TJANK's Avatar
TJANK
I know this will sound strange but there is a simple solution to increase the range for the fob and it works.
The “trick” of using your head to increase the key fob’s range also seems to work as well or even better by placing the fob under your chin, sometimes accompanied by opening your mouth.
Video test:
Jeremy tests central locking range - Top Gear - BBC
Old Dec 16, 2013 | 07:34 PM
mikey_t's Avatar
mikey_t
i remember seeing that episode then going out to try it......and it worked. Of course i may have looked like a bit of a doofus.....
Old Dec 16, 2013 | 07:38 PM
Fly'n Brick's Avatar
Fly'n Brick
This is an old issue. Holding the key up to your jaw or temple can get the range out to an easy sand wedge distance. The main complaint, as I remember, was the threat of 'looking like a dork' while executing this maneuver.
I'm not a dork but I often resemble one from half a block away.
Ive's Mini's Avatar
Ive's Mini
I have been using that technique for 25 years! It works!
Old Dec 17, 2013 | 02:29 AM
jake1's Avatar
jake1
Might just be the height and position of the fob.
Video test:
Jeremy tests central locking range - Top Gear - BBC - YouTube
I've read some articles written by engineers that say this effect has more to do with the height that you hold the key fob and not with any contact to your head. They discuss how the key fob's are constructed and their omni-directional output and it sounds more like how the fob is held and the height that accounts for the increased reception. They also point out that the human body actually absorbs the signals instead of acting like some kind of antenna.
Old Dec 17, 2013 | 05:32 AM
mikey_t's Avatar
mikey_t
There is always someone who will 'poo-poo' something that works....
Old Dec 19, 2013 | 03:20 PM
gremlin's Avatar
gremlin
The issue I would guess RavenGirl is referring too is that with the convenience package the idea was don't remove the key from your pocket, with my wife's Audi we only need be near the door and it works, with the Mini if it's in my back pocket which is away from the trunk it doesn't work. It's really far to weak.
Old Dec 21, 2013 | 01:09 PM
chanclor's Avatar
chanclor
I have the convenience package and have the same issue with the very short range. Even using the convenience button on the door handle will often not work on the first try... so I'm sitting there moving my leg as close as possible to the door!
But if that's my biggest gripe, I guess I don't have much to complain about.
Old Feb 3, 2014 | 01:08 PM
RavenGirl's Avatar
RavenGirl
I ran the software update that I found on the miniusa website, and it seems to have gotten worse. I can be standing against the car holding the button and it rarely works. :(
OutMotoring
Nov 16, 2015 07:04 AM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
ir0nhid3
Sep 18, 2015 07:52 AM
MiniUnz
Sep 14, 2015 11:11 AM
