R50/53 Supercharger problem
Old Dec 13, 2013 | 10:42 AM
Edgpr's Avatar
Edgpr
Hi, I have an 04 Copper S in which the supercharger started making a loud whining noise every time u touched the accelerator. It is not the usual spinning noise of the SC which in familiar with, is a different louder spinning noise like. So I read a few threads and learned that SC tend to fail around 110k to 130k which is around what my car has right now. I have pulled the SC out following a forum DYI and I was planning to change the oil hoping that maybe it was just low in oil, but now that is out I'm wondering if there is anything else I could do to confirm if the SC is indeed bad and not just low in oil. I wouldn't wanna have to remove this thing again since is a time consuming job. Any help will be greatly appreciated. Thank you. Ed
Dupplicate thread...sorry, how do I delete it ???
Old Dec 13, 2013 | 10:58 AM
ZippyNH's Avatar
ZippyNH
You try checking the belt?
Other than that....when the sc goes bad...time to swap it.
If the oil is low...from presumably a bad seal...doing 8 hours of labour to remove it...fit it, replace it is a waste as it will go low again....and you need about $50-65 is new gaskets to do it...
Old Dec 13, 2013 | 11:33 AM
Edgpr's Avatar
Edgpr
Belt is good. Makes sense, but I can't afford to replace the whole SC right now so I guess I have to extend it for a little n duplicate labor 😣
Old Dec 13, 2013 | 12:58 PM
paco1076's Avatar
paco1076
There is an idler pulley that is part of the sc system. When you change the belt, change that pulley as well. Will cost you a few extra bucks on the front end, but will help the system last longer. The noise is more likely coming from the pulley going bad.
alistaircookie
Oct 8, 2015 10:52 AM
Jacob Kenney
Sep 1, 2015 10:22 AM
5904
Aug 27, 2015 10:00 PM
Aug 27, 2015 03:18 PM
Aug 25, 2015 01:28 PM
