R56 cold weather high idle?
Old Dec 12, 2013 | 12:57 PM
nick654377's Avatar
nick654377
So this morning it was 6*f when I got up for work. I always let my cars run for 5-10 minutes to get the fluids warmed up. My mcs is a 2008 and just had the timing chain, water pump, and turbo heat shield done on it. I changed the oil with mobil 1 0w-40 and everything has been fine.
Well this morning when I started it up the idle turned up to 1500 rpm and would drop down to 1200 and back up to 1500. I thought it was just a warm up period being so cold that mini had. (my first non American car) well after 10 minutes I go back to the car and noticed I believe it was the CEL on and it was showing half yellow and half empty. I shut the car off and restarted it and everything was fine.
Any ideas on what this can be?
Old Dec 12, 2013 | 01:40 PM
oldsbear's Avatar
oldsbear
My 2007 MCSm behaved that way at around 0 F. MINI service guys said it was intake icing. Maybe by now they have a fix for it.
Old Dec 12, 2013 | 01:44 PM
nick654377's Avatar
nick654377
did you also have a dead pedal? did you do anything about it? how many times has it happened to you?
Old Dec 12, 2013 | 01:45 PM
Pno2nr's Avatar
Pno2nr
Wow. I have to put my gas pedal down about half way (as the manual sez) to start it up. I have to purposely keep the rpm's up a bit like 1500 or it will stall for the first 30 seconds or so. '05 MCS It's grumpy for a few minutes, then gets used to it. It was -7 Tuesday.
TREX
Nov 2, 2019 07:31 PM
Dec 23, 2015 10:36 AM
minicoclub
Aug 25, 2015 09:07 AM
DiGiPiMP
Aug 24, 2015 11:04 AM
