R56 scan gauge question
Old Dec 11, 2013 | 05:14 PM
miniSherlock92's Avatar
miniSherlock92
scan gauge question
Any adjustments I should make for my 2012 cooper? I pulled 133 hp on it and I believe its a little off seeing as I only have an intake. Any and all info is helpful, thanks.
Old Dec 11, 2013 | 05:35 PM
richardsperry's Avatar
richardsperry
What?
Old Dec 11, 2013 | 06:21 PM
vetsvette's Avatar
vetsvette
Moderator
Old Dec 11, 2013 | 06:43 PM
miniSherlock92
Nevermind, i'm just not going to mess with the settings. sorry to confuse you.
Old Dec 11, 2013 | 08:53 PM
trwxxa's Avatar
trwxxa
Originally Posted by vetsvette
+1
Old Dec 11, 2013 | 09:25 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
make sure you have everything programmed in it correctly like engine size and I think you can even put weight in somewhere. The gauge is just a guess as it calculates it off rpm, and rate of accel, so it's not perfect as many factors like aerodynamics aren't factored.
Old Dec 12, 2013 | 09:21 AM
miniSherlock92
Thanks, I got everything set, I figured it wasn't super accurate as its based off calculations. Now its time to get the temp numbers down, and hp numbers up
maniacalmorgan
38
Sep 29, 2015 04:56 AM
missinmyjeep
Aug 22, 2015 07:13 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
tylewis
Aug 18, 2015 06:53 AM
PSIChocolate
Aug 13, 2015 12:46 PM
