R50/53 Adjust height of facelift R53 xenon headlights
Thank you!
I assume when you mean inner and outer that when face the front of the car and I raise the hood up the *inner* for the driver side would be the screw closest to the passenger side and vice versa, yes? I am really hoping someone can just take one example picture and point out the height screw. I am very afraid to eff this up like I did in my first car.
Thank you!
Just wanted to thank you for the pic and info, actulsiz! This thread helped me re-aim my headlights, which have been cocked way off to the right since I bought the car (SEVEN years ago!).
I used a B&D electric screwdriver with a socket on the end to make the adjustments with the hood open and the headlights pointing up at the open garage door above. I used chalk to make the center of each headlight pattern first so I could tell which way I was moving the beams. It took two or three adjustments to get them dialed in, but they are finally spot-on!
Yes, The factory lights from the pre 7/2004 cars with Factory Xenon will swap to he 7/2004+ cars with Factory Xenon. You will have to swap over the headlight washers and the covers.
63127198739
http://www.ecstuning.com/Search/SiteSearch/63127198739/
63127198740
http://www.ecstuning.com/Search/SiteSearch/63127198740/
63127198739
63127198740
63127198739
63127198740
63127198739
63127198740
Thanks for taking the time to respond!!!!
This will be my little summer project
Welcome.
Dec 23, 2015 10:36 AM
