anyone know how to adjust the xenon headlight?
Old Dec 10, 2013 | 02:53 PM
docpat99's Avatar
docpat99
Hi anyone know how to adjust the xenon headlights on the countryman? Mine seems to high, is it advisable to adjust it on my own or should i go to the dealer thanks
Old Jan 2, 2014 | 07:21 AM
xenor's Avatar
xenor
There's screws to adjust up or down. Mine were not correct when delivered so I adjusted myself. You can adjust the cutoff line on the projector as well as mine was not focused correctly either.
Old Jan 22, 2014 | 04:24 PM
IRoNoRE's Avatar
IRoNoRE
xenon's are self adjusting.
Old Jan 22, 2014 | 04:31 PM
xenor's Avatar
xenor
IRoNoRE, they are not self adjusting, but self leveling. They have hard adjustments independent of level sensor status, as well as fine adjustment of cutoff shield on the projector.
That said, adjustment should only be performed with the headlights in adjustment mode, or at least level ground. This will prevent over adjustment up or down which can damage the levelling motors.
Old Jan 22, 2014 | 10:27 PM
HorseWithNoName's Avatar
HorseWithNoName
How do you adjust the cut off shield focus and what is adjustment mode?
My lights need to come down some.
Thanks...
Old Aug 16, 2014 | 07:31 PM
Firesale's Avatar
Firesale
I have a 2010 Mayfair that I overdrove my headlights at 35 MPH. The dealer said no to adjusting the vertical when asked so I looked long and hard. Voila'. There on the engine side on both, drivers side left, passengers right side is a WHITE plastic hex nut head . It is a metric allen wrench size 6mm. Turn this screw CLOCKWISE and it will RAISE the headlight beam. I parked in front of my apartment building about four feet away from the wall and I achieved a raising of the light beam one full brick high. Enough for my lights to actually light the road ahead of me for a safe distance without having to turn on my high beams!!!! BTW the dealer mechanic's reply when I complained I couldn't see the road ahead of me was to install xenon fog lights. Is there some kind of Mini dealer policy NOT to correct the adjustments on these xenons?
ryGuyMCS
Oct 6, 2015 12:04 PM
rbarakat
Oct 3, 2015 11:08 PM
molala
Oct 2, 2015 01:53 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
