R56 GP1 side skirts on an R56
I was wondering if anybody knew if the R53 and R56 side skirts are the same dimensions and/or are interchangible. I have an R56 with the JCW Aero kit, but the link below shows a guy with an R56 with GP1 side skirts and I would love to add them to my car:
http://www.minitorque.com/forum/f272...57/index2.html
Possible it could be done, they are generally the same. I don't have the exact lentgh of each one to see if they line up with arches to arch. The under body part I believe has different alignment holes and connections.
R53 JCW GP 1 Side skirt
VS
JCW Aero R56 side skirt
Might take some work but possible.
VS
Here is the list of parts for the GP1 Side skirts ( 2006 MINI GP ). This is the total list of parts and hardware from the original GP. Parts that need painted are primed.
#1 Left and right Part # 51777182557 & 51777182558 Primed
http://www.ecstuning.com/Search/SiteSearch/51777182557/
http://www.ecstuning.com/Search/SiteSearch/51777182558/
#2 Left and right Part # 51777182561 & 51777182562
http://www.ecstuning.com/Search/SiteSearch/51777182561/
http://www.ecstuning.com/Search/SiteSearch/51777182562/
#3 The support ( inner ) left and right side. Part # 51777182631 & 51777182632
http://www.ecstuning.com/Search/SiteSearch/51777182631/
http://www.ecstuning.com/Search/SiteSearch/51777182632/
#4 Front cover left or right ( so x 2 ) this is numbered wrong on the pic( should be #6.
http://www.ecstuning.com/Search/SiteSearch/51777186270/
#6 Cover for jack fixture, rear left & rear right
http://www.ecstuning.com/Search/SiteSearch/51777186271/
http://www.ecstuning.com/Search/SiteSearch/51777186272/
GP jack extension piece x 4
http://www.ecstuning.com/Search/SiteSearch/51717188454/
And the hardware is listed below:
Hardware:
http://www.ecstuning.com/Search/SiteSearch/07131480419/ #8 x 18
http://www.ecstuning.com/Search/SiteSearch/51711496621/ #9 x 8
http://www.ecstuning.com/Search/SiteSearch/07137073915/ #10 x 4
http://www.ecstuning.com/Search/SiteSearch/07130702966/ #11 x 12
http://www.ecstuning.com/Search/SiteSearch/07147154447/ #12 x 20
http://www.ecstuning.com/Search/SiteSearch/07147129160/ES16849/ #13 x 20
http://www.ecstuning.com/Search/SiteSearch/07131484155/ #14 x 4
http://www.ecstuning.com/Search/SiteSearch/51451857745/ #15 x 2
These are the GP door sill covers: Which one is used for each door. But that's if you want to use that style otherwise any other R50-R57 door sill will work.
http://www.ecstuning.com/Search/SiteSearch/51777182559/
Hardware:
jwmolmen
Sep 22, 2015 10:00 AM
thebordella
Aug 31, 2015 01:37 PM
cm.d
Aug 19, 2015 08:51 AM
