Navigation & Audio R56 Cooper S iPad Mini Dashboard Project
Old Nov 18, 2013 | 12:22 PM
immo's Avatar
immo
These pictures above are from my latest setup. I used an iOttie suction cup and a speck iPad cover to put the iPad in the central dash. But the looks were not for me. I wanted something looking more stock-ish.
Photos are taken with iPhone, sorry about the bad image quality.
Now for the FAQ's:
1. My head unit is a Pioneer DEH-X9550BT hidden in the secret compartment, driven by a Match PP52DSP 5channel amp.
2. The rear speakers of the Boost headunit are plugged in the stock front mid-range speakers. (I have 2way focals, 16cms are in their place, and the tweeters are in the A-pillar so the midranges are not used.) This way I didn't lose my stock PDC.
3. I can see everything through the DashCommand app via the Kiwi 2 wi-fi device. So I really don't need the central speedometer.
4. I seriously need an anti-glare screen protector, as the iPad is not bright enough for sunny daytime use.
5. I use bluetooth, or the USB cable to stream audio through the Pioneer HU.
6. I am using a Metra Axxess ASWC in order to use my MFSW with the aftermarket HU. Works like a charm.
If you have any further questions I will be more than happy to answer.
Now after this adventure, I made up my mind, and decided that I can give up my speedometer in order to keep the iPad Mini in my Mini.
And this morning we started the project:
My inspiration was this video by
First we took the central piece out and we begun.
We bought another iPad cover and use it as a mold.
We put the right piece to our Dremel and the smashing has begun:
We put the central piece back to check if it sits right.
And afterwards, we cut some carton in order to fill the gaps.
The gaps are finally filled:
After covering it with carton, we used some polyester.
After the polyester has dried, we used some polyester putty to give a better shape:
We wanted to speed things up a little :
And sanding begins:
First trial after sanding
After trials, we saw that we needed more putty, and we put another layer.
Last sanding job:
And finally we used some glazing spot filler, and lay the piece to dry till tomorrow.
To be continued...
Old Nov 18, 2013 | 12:23 PM
immo's Avatar
immo
After a coat of plastidip:
Testing if the iPad sits flush or not after the paint is dry.
Final tests on the car before going to the upholstery shop:
A sneak peak to the DashCommand app running :
Finally, I took the piece to the upholstery shop, and left it there. The guy said it would take him 2 days to finish the job.
Fingers crossed
Old Nov 19, 2013 | 02:22 PM
immo's Avatar
immo
Coming close to the final product
Old Jan 29, 2014 | 02:55 PM
immo's Avatar
immo
It really held on good for a while, but then I fell in love with Duell AG's gaugefaces and pulled the ipad out of the car.
Attached Thumbnails R56 Cooper S iPad Mini Dashboard Project-image-3583119306.jpg   R56 Cooper S iPad Mini Dashboard Project-image-26862047.jpg   R56 Cooper S iPad Mini Dashboard Project-image-3317442500.jpg
Old Jan 31, 2014 | 09:14 AM
jeffl1980's Avatar
jeffl1980
Very well done!
Old Feb 8, 2014 | 07:19 AM
recordsmith's Avatar
recordsmith
I love what you did. I'm gonna give it a try when I get my r58 in 6 weeks. Thanks for for the inspiration! You are the only person to even attempt it. Bravo
Old Feb 8, 2014 | 08:38 PM
zrickety's Avatar
zrickety
Very cool.
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 26, 2015 01:02 PM
marendt428
Aug 8, 2015 04:44 AM
PelicanParts.com
Aug 7, 2015 08:39 AM
