R60 R60 2011 Countryman Fuel Filter and Fuel Pump
Old Nov 18, 2013 | 09:19 AM
G3NSM0R3S's Avatar
G3NSM0R3S
This is how to change the Fuel Pump in your R60. The R60 does not have have a replaceable Fuel Filter, it is built into the Fuel Pump, this is what was said to me from the MINI dealer and after getting to the pump. So don't waste your time and money needing to change a Fuel Filter like I did.
To change the Fuel Pump remove the passenger rear seat by removing the plastic covers
Place a Flat Head Screwdriver on the metal rail behind the plastic cover and tile the screwdriver back to pop off the covers.
using a 5/8 socket at 25ftlb to remove the rear seat nuts and the front seat bolt using a 50mm Torx at 50ftlb.
Once the seat is removed there is a perforated cut of the fuel pump cover.
Use scissors to cut the tiny connections and fold back the carpet to reveal the cover.
Remove Cover by folding it over to the drive side rear seat
Remove the 5 nuts. Remove Cap. MAKE NOTE OF THE ARROW POINTING
You may want to vacuum the dirt that will be on top of the fuel tank.
To disconnect the fuel line there are two small holes that hold the blue clip in, once you release this clip you have 5 seconds or less till the fuel line pressure forces the line to separate from the fuel pump connection, so keep a hand on that connection and place towels around to absorb the gas that will pour out until the pressure is equalized.
The electric connection lift the latch up push the device towards the door
and then lift up once the notches look like this
Now to remove the locking ring you can take a hammer/mallet and a flat head screw driver and place it on one of the notches in the ring and nock it counter-clockwise to loosen it or if you have enough strength to loosen it with you bare hands by all means just remember righty tight, lefty loosey. Remove ring.
Pull the Fuel pump up SLOWLY so you do not damage the Fuel Level Float arm. Fuel will leak out of the bottom so have extra absorbing material ready. And remember to place a cover over the exposed fuel so nothing will get in it.
To reassemble just follow this non-expert guide in reverse.
Having an issue posting pictures. They can be located here http://flic.kr/s/aHsjMERonU
Old Nov 18, 2013 | 10:09 AM
shark715's Avatar
shark715
How much did it cost? Does the factory maintainence schedule call for it to be replaced?
Old Nov 18, 2013 | 10:39 AM
G3NSM0R3S's Avatar
G3NSM0R3S
They said if you needed a fuel pump replacement it would be a $1200 repair. I did not ask about warranty coverage or the maintenance coverage. I think the part it self is $300 or more.
Old Nov 18, 2013 | 12:32 PM
G3NSM0R3S's Avatar
G3NSM0R3S
The cost for the dealer to replace the fuel pump is $1200 in my area. The part is at least $300. I did not ask if it is covered under the warranty or maintenance plan that BMW/MINI offer, since my car is over 67K miles and bought it used. Just wasted a Saturday morning finding out that the filter does not get replaced unless the pump goes out. I am returning the $52 fuel filter.
Old Nov 19, 2013 | 07:06 AM
shark715's Avatar
shark715
Thanks. I did not recall seeing any mention of the fuel filter in the maintainance schedule and I thought maybe I had missed something.
Old Nov 19, 2013 | 07:51 AM
G3NSM0R3S's Avatar
G3NSM0R3S
You are welcome. Sorry for the double post reply. but now there is a handy guide to replace a R60 Fuel Pump.
Tah-Dah
Old Nov 20, 2013 | 02:44 PM
DrewNJ's Avatar
DrewNJ
Nice work! Seems like a pretty straight forward swap out.
Did your pump go bad? Seems like low mileage for a fuel pump to die.
Old Nov 20, 2013 | 04:57 PM
Hogan3's Avatar
Hogan3
Mine had to be replaced this week at 8000 miles. Was driving on the freeway and the engine just stopped. The tech who worked on my car said that it's a very common repair on the CM.
Old Nov 20, 2013 | 05:03 PM
Minime2014's Avatar
Minime2014
Yep! Mine failed when the car was 2 days old, and unfortunately my car had to be towed to the dealer twice before they figured out what the problem was.
Old Oct 24, 2014 | 02:35 PM
G3NSM0R3S's Avatar
G3NSM0R3S
No it didn't go out, just thought the filter needed to be replaced.
Old Oct 3, 2016 | 08:47 PM
Theemasonator's Avatar
Theemasonator
Does anyone know where the fuel filter is on the r60 sALL4
Old Oct 3, 2016 | 09:26 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
It is in the first post, part of the in tank fuel pump.
Old Oct 3, 2016 | 09:32 PM
Theemasonator
Thank you, guess I should have read better
Old Jun 15, 2025 | 09:21 AM
RobbieDarryl's Avatar
RobbieDarryl
I'm just attempting this now on my daughter's Countryman. What is the easiest way to release that blue clip? I've been poking and prodding and am afraid of breaking it.
Old Jun 15, 2025 | 11:30 AM
G3NSM0R3S's Avatar
G3NSM0R3S
my friend I wish I could remember. I traded it in may of 2015 for an F55. But if I am thinking of the blue clip you’re referring to, it’s with you press down as hard as you can and pull it buy one of those tools that makes pressing the button a lot easier. Or if it’s a clip take a smallest flat heat you have and help move the clip in the unlock direction. I wish I took pictures when I did this so long ago.
Old Jun 15, 2025 | 11:49 AM
RobbieDarryl
Wow, with this thread being so old i wasn't really expecting a reply. Thank you!
I managed it with two very tiny flat head screw drivers. If this doesn't solve my problems it looks like the high pressure fuel pump is next.
Thanks again!
Old Jun 15, 2025 | 12:51 PM
G3NSM0R3S's Avatar
G3NSM0R3S
Thanks again!
you’re welcome sir.
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
Aug 13, 2015 12:57 PM
Aug 13, 2015 12:56 PM
Aug 12, 2015 01:24 PM
bc219
Aug 10, 2015 11:22 AM
