Drivetrain Tyrol Sport Caliper Bushings -Ok on a winter driven car?
Old Nov 14, 2013 | 12:00 PM
Matt Moore's Avatar
Matt Moore
My rubber caliper bushings are crap.
Would Tyrol Sport Caliper Bushings stand up to road salt and winter driving?
I have had enough of the sub-par braking because of slow caliper sliders.
thanks,
Matt
Old Nov 14, 2013 | 12:16 PM
jasonsmf's Avatar
jasonsmf
I run them year round in northern Ohio, no problems although I usually clean and re grease them once or twice annually.
Jason
Old Nov 14, 2013 | 01:58 PM
GreekDrifter91's Avatar
GreekDrifter91
im not sure I could feel any more stiffness with them but I do use a lot of silver anti seize on the slides so that they don't seize I was using grease before and my rear brakes would always seize. switched to silver anit-seize and slobered it all over the place have yet to have a problem!
Old Nov 14, 2013 | 02:02 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes just make sure you lube them at least once a year and you should be good. We keep the bushings in stock.
http://www.waymotorworks.com/tyrolsp...ini-front.html
Old Nov 14, 2013 | 02:47 PM
ashchuckton's Avatar
ashchuckton
You won't feel a difference, but if you brake hard & use your brakes they will keep your pads wearing evenly. With proper lubing they will be just fine in the winter.
Old Nov 14, 2013 | 03:09 PM
Matt Moore's Avatar
Matt Moore
Ash,
I lubed up the sliders and replaced the rubber, they still don't slide well like a proper slide pin should.
Need something different, not for the feel.
Feel would be stainless lines and pads.
Old Nov 14, 2013 | 03:47 PM
bahawton's Avatar
bahawton
The revised version come with a dust cap:
http://www.tyrolsport.com/minircs
Old Nov 14, 2013 | 04:21 PM
GreekDrifter91
Hmmm. Looks like something anyone can by and stick on I'll go look at like home depot for those rubber caps.
Old Nov 15, 2013 | 11:24 AM
Eric_Rowland's Avatar
Eric_Rowland
I don't think that will work. As I recall, there isn't much of a lip on the bushings. Revised ones are extended so there is material to put the cap over.
Toolman
Jan 20, 2016 06:50 AM
xpunisherx
Aug 10, 2015 10:50 PM
Dashdog
Aug 10, 2015 06:17 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
