Fillers for deep scratches?
Old Nov 5, 2013 | 08:47 PM
Anldyxp_R56's Avatar
Anldyxp_R56
Hi guys, I just bought a used Cooper S and it has a couple of deep rock chips on the hood. The chips are through the clear coat and paint. I was wondering if anyone could recommend any putty or resin products that I can use as filler? Repair kits? I already purchased the Mini touch up paint for after I fill in the chips. Thanks!
Old Nov 6, 2013 | 03:39 AM
Beachnmini's Avatar
Beachnmini
If you fill it, you'll have to sand it, which will make it bigger to paint. Just touch up with paint OR spend the $ for a repaint IMO.
Old Nov 6, 2013 | 03:47 AM
Capt_bj's Avatar
Capt_bj
the MINI t/u paint is very thick ... just build up coats ... you'll probably end up with a raised blob which you can then safely work on with
http://www.langka.com/
Old Nov 6, 2013 | 08:25 AM
Anldyxp_R56
Thanks guys. Have you guys ever heard of Scratch Wizard? It uses a putty that you squeegee off, leaving the putty only in the scratch or chip, than you paint over it. The kit comes with touch up paint but you can also order it without the paint for $25. http://scratchwizard.net/touch-up-kits/scratchwizard/
Old Nov 6, 2013 | 03:08 PM
Beachnmini's Avatar
Beachnmini
No, I've not seen it. But I've also never seen a patch that didn't need sanded, on anything. I'd just use t/u paint myself (which I also need to do to mine) good luck!
Old Nov 6, 2013 | 04:32 PM
Anldyxp_R56
Ok, thank you!
M7Speed
Jul 10, 2018 09:26 AM
jeri534
Nov 6, 2015 01:40 PM
Ovrclck
Oct 5, 2015 09:45 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
BMC_Kid
Sep 27, 2015 04:31 PM
