Fillers for deep scratches?
Hi guys, I just bought a used Cooper S and it has a couple of deep rock chips on the hood. The chips are through the clear coat and paint. I was wondering if anyone could recommend any putty or resin products that I can use as filler? Repair kits? I already purchased the Mini touch up paint for after I fill in the chips. Thanks!
the MINI t/u paint is very thick ... just build up coats ... you'll probably end up with a raised blob which you can then safely work on with
http://www.langka.com/
Thanks guys. Have you guys ever heard of Scratch Wizard? It uses a putty that you squeegee off, leaving the putty only in the scratch or chip, than you paint over it. The kit comes with touch up paint but you can also order it without the paint for $25. http://scratchwizard.net/touch-up-kits/scratchwizard/
M7Speed
R60 :: Countryman Talk (2010-2015)
07-10-2018 09:26 AM
