H Stock Strut and Shock work
Old Nov 4, 2013 | 05:45 PM
TopLegion's Avatar
TopLegion
I am looking for some shocks and struts for my mini for the next autox season. I looked at the koni yellows which allow ajustable rebound stiffness and will complement a 25mm sway bar very nicely to bring the *** end around. Is this the best way to go? Are there other options in terms of shocks and struts?
Old Nov 5, 2013 | 07:00 PM
Mini2na's Avatar
Mini2na
I went with the Koni Yellows and a 22mm solid bar. So I'd say you got it right, but if I had more $$ I'd have gone with some custom valved Bilsteins from Fat Cat Motorsports.
Others can chime in, but I think those are the two most chosen options, unless you are jumping out of stock/street... then coilovers are an option.
Old Nov 6, 2013 | 04:58 AM
v10climber's Avatar
v10climber
The Koni yellows would be a great choice. There are other options but you probably don't want to hear the cost and they would have to be custom fabricated anyways.
Old Nov 6, 2013 | 06:01 AM
kyoo's Avatar
kyoo
personally going the bilstein sport route - not sure if I'll have them custom valved from the getgo though..
Old Nov 6, 2013 | 09:18 AM
TopLegion's Avatar
TopLegion
Are the Bilsteins coilovers? Cause those are not stock legal. I am building the car for stock class.
Old Nov 6, 2013 | 09:25 AM
kyoo's Avatar
kyoo
me too - see the build in my sig.
bilstein HD and sports are just dampers, which are stock legal. Monotube gas. According to more than a few people, the bilstein sports revalved should be as good as anything for stock class. cant afford what FCM asks for a revalve quite yet, so I think I'm gonna run with the sports stock for a while. Was going to go with the Konis, but for the rears you have to remove them to adjust anyway, which can take a toll on the threads in the rear control arm I believe. So at least for the rears, just want a high quality set and forget setup. That was my thinking anyway, all but certain I'll be running the Bilstein sports next season. I had the Bilstein HDs on my evo, was a great setup.
Old Nov 6, 2013 | 04:29 PM
archdukeferdinand's Avatar
archdukeferdinand
The problem is that the adjusting the rears is the easiest way to tune the car's handling. I've had mine in and out at least a dozen times now and the threads seem fine. Just be gentle and hand thread and don't over-torque.
Old Nov 6, 2013 | 05:21 PM
kyoo's Avatar
kyoo
i agree, definitely a valuable degree of freedom as far as tuning handling. personally though, i'll just be adjusting tire pressures and adjusting rear bar if necessary. i think the bilstein shocks are worth giving that up, esp once revalved. we'll see though
Old Nov 6, 2013 | 07:30 PM
TopLegion's Avatar
TopLegion
I have seen someone in a mini adjust bump stiffness without taking the shocks off. The yellows are out of the question if I have to remove them to do adjustments
Old Nov 6, 2013 | 07:36 PM
kyoo's Avatar
kyoo
i believe so, just the rears obviously, unless you've got a jcw front strut tower brace (which I do as well). adjustability is nice (i've got ohlins on the evo) but for the mini i'd rather just get an awesome damper in a set-it-and-forget-it format. one of the suspension gurus around here will tell u the bilstein sports are as good as the koni yellows, and that's before revalving.
your call of course. adjustability is nice, but seems a pain in this set up. for the evo, the adjusters for front are on the bottom, and for the rears it's just a matter of removing the trunk liner, which i just leave out these days
i checked with FCM about valving the bilsteins to spec though.... it costs more than the bilsteins themselves
Toolman
Jan 20, 2016 06:50 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
