Drivetrain Fix your sloppy shifter now!!
Old Oct 31, 2013 | 12:42 PM
Quitman Rhinehardt's Avatar
Quitman Rhinehardt
I finally found a fix for the bad bushing in the shifter arm. Mini doesn't sell it but Ford does sell an identical bushing made for the ford focus SVT which coincidentally has the same transmission.
Only for early style shifter assemblys made prior to 2004.
Attached Thumbnails Fix your sloppy shifter now!!-forumrunner_20131031_154242.jpg
Old Oct 31, 2013 | 01:06 PM
bahawton's Avatar
bahawton
Nice find!
Old Oct 31, 2013 | 01:09 PM
Quitman Rhinehardt
Yeah I broke the one that came with my Megan short shifter and the original one is garbage.
Old Oct 31, 2013 | 02:32 PM
GreekDrifter91's Avatar
GreekDrifter91
the part number on that is 97ZZ-7335-AA right? how much? ford is right down the street from me. and did you get one or two?
Old Oct 31, 2013 | 03:39 PM
Quitman Rhinehardt
Yes that's the part number. Comes with 1 bushing for 14$. I also ordered the same one from eBay a bit cheaper. In the pic the yucky looking one on the left is the original bushing.
Old Oct 31, 2013 | 04:44 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Quitman Rhinehardt
...Comes with 1 bushing for 14$....
Good find but 14 bucks? Ouch!
///Me
Old Oct 31, 2013 | 05:11 PM
Quitman Rhinehardt
Unfortunately its a dealer only item. Even the ebay one was from a dealership.
Old Oct 31, 2013 | 09:10 PM
GreekDrifter91
do you need two? one for the horizontal post and one for the vertical post?
Old Nov 1, 2013 | 12:23 AM
nismo4life's Avatar
nismo4life
Hmm. I dont recall seeing that when I took apart my shifter box to install the SSK. Anyone have a photo showing where it goes?
Old Nov 1, 2013 | 01:34 AM
Quitman Rhinehardt
You only need one and it goes inside the arm on the side of the shifter assembly. Snaps on the shifter itself.
Old Nov 1, 2013 | 04:17 AM
minsanity's Avatar
minsanity
A buddy's R53 shifter lost the defined knotch betwwen first & reverse. To the point of inadvertent engaging reverse instead of 1st gear at times. Is this the kind of slop you felt w/ yours?
Old Nov 1, 2013 | 04:30 AM
Quitman Rhinehardt
Mine just had a lot of side to side movement while in gear. Its possible that it just hadn't reach that point like your friends mini.
Old Nov 1, 2013 | 04:41 AM
minsanity's Avatar
minsanity
Makes sense. $14 trial isn't bad at all. Thanks, Q.
Old Nov 2, 2013 | 02:26 PM
nismo4life's Avatar
nismo4life
It should be noted that this is NOT for the facelift cars with the newer style shift box. It does not work on my 06.
I have one of these bushings if anyone is looking to buy it :D.
Old Nov 2, 2013 | 05:59 PM
Quitman Rhinehardt
The newer style started in 2004 I believe.
Old Nov 2, 2013 | 06:40 PM
nismo4life's Avatar
nismo4life
I know. You should put an edit on your original post for anyone who uses this as future reference that it only will fit the metal shifter brackets, not the revised box with the plastic one.
Old Nov 2, 2013 | 09:42 PM
Quitman Rhinehardt
Here are the two versions. This works for the type "b" version.
Old Nov 4, 2013 | 11:50 AM
Manny_cooper's Avatar
Manny_cooper
Is there any fix for the face-lift ones?
Old Nov 4, 2013 | 01:40 PM
nismo4life's Avatar
nismo4life
I played around with mine after I had everything apart realizing the hard way this bushing doesn't work on ours lol. There are these little plastic washers that seem to wear out, but BMW doesn't sell them...obviously . Going to have to spend some time in the hardware department, or see if I can have someone make them.
Old Nov 4, 2013 | 03:37 PM
GreekDrifter91
you can probably get some teflon rod stock and make a few of those spacers/ washers for your face lift style.
Old Nov 7, 2013 | 09:59 AM
a32guy's Avatar
a32guy
How about the bushing that snaps around the ball? Looks alot like BMW ones, I wonder if a BMW part would fit?
Old Nov 7, 2013 | 10:09 AM
exocet's Avatar
exocet
Do you have to get underneath the car to replace this bushing?
I have left-right play in the shifter while in gear, not bugging me right now, but if it's an easy fix from inside the car, will switch em out
Old Nov 7, 2013 | 10:44 AM
nismo4life's Avatar
nismo4life
Don't think so. They look like little hats, its a washer with a cylinder going into the shifter box on each side. I'll figure out something.
Old Nov 8, 2013 | 03:26 AM
Quitman Rhinehardt
No you don't. Unplug the seat heater switches, pull up boot, 4 Phillips head screws and lift the whole console up. Can be tricky getting the new one in though. Put some metal between the arm and the shifter base and then use a hammer tap it in.
Old Nov 8, 2013 | 05:24 AM
exocet's Avatar
exocet
Sweet! Thanks, will get one and give it a whirl. Will be nice not to have the play while in gear as I usually leave my hand on the stick - probably why it's bust in the first place
