R52 Removing center console
Old Oct 14, 2013 | 04:13 PM
I CHA 3X's Avatar
I CHA 3X
can anyone tell me please how to remove the center console below the speedometer so I can remove the radio down tubes?
thank you.
Old Oct 15, 2013 | 10:39 AM
ranczar's Avatar
ranczar
Here is a good thread for you to read: READ THIS
Old Oct 16, 2013 | 05:42 PM
joylove's Avatar
joylove
If you want to full remove the down tubes, the grey trim in front of the speedo needs to come off.
You can unscrew the four screws and slide them up then flare to teh side, eg to unscrew the radio, but to remove, the trim around the speedo needs to come off.
To access the screw on the steering wheel side of the car, pull down on the trim, it is how you access the fuse box.
I CHA 3X's Avatar
I CHA 3X
thanks, i looked it over but still stuck on how to remove the console tunnel section. the only screws I can see are inside the cup holders.
Old Oct 17, 2013 | 08:28 AM
joylove's Avatar
joylove
What exactly are you trying to do? remove the downtubes, move the downtubes to remove remove the radio or remove the cup holders?
Old Oct 17, 2013 | 09:30 AM
I CHA 3X's Avatar
I CHA 3X
remove the downtubes so i can install my wyatt cup holders. the 06 has a lip on the bottom of the tubes so the center console has to come out and pull the downtubes from below.
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
xraycat
Aug 12, 2015 02:36 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
