Drivetrain sensor O2 post cat.
Old Oct 10, 2013 | 09:59 AM
minijuri's Avatar
minijuri
sensor O2 post cat.
hello.
I do not speak English and I translated with google translated.
I would like to remove the oxygen sensor after the catalytic converter
if I insert my file in the discussion my file ECU could you help me?
I want to eliminate the lambda probe downstream
please!!!!!
Old Oct 11, 2013 | 07:06 AM
Saltysalt's Avatar
Saltysalt
put a 90 deg elbow in the O2 sensor bung
Old Oct 11, 2013 | 07:10 AM
leaf_fan_1988's Avatar
leaf_fan_1988
What benefit is there of eliminating the down stream o2 sensor?
Old Oct 14, 2013 | 05:44 PM
Saltysalt's Avatar
Saltysalt
if you go catless you wont throw a code
Old Oct 14, 2013 | 07:17 PM
05r50's Avatar
05r50
I think your question is whether you can have your car tuned to ignore the post cat O2 sensor so that if you are using a catless downpipe it won't throw a code. Correct?
The 90 degree bung adapter for the O2 sensor is a hit or miss. I have tried 2 different variations and I still throw a code.
I haven't had the ECU tuned to ignore the CEL. I just clear the code.
Old Oct 16, 2013 | 12:31 PM
TheBigChill's Avatar
TheBigChill
Mechanical: http://www.summitracing.com/parts/vp...FcxaMgod8xgA-A
Has worked over 8 months for me, and never a CEL. (used smallest insert)
Electrical: http://www.o2simulator.com/index.php...&products_id=8 OR http://www.symtechlabs.com/catalog/i...ator-p-34.html
Old Oct 18, 2013 | 07:50 AM
lowsid3r's Avatar
lowsid3r
They also make a "mini cat" o2 sensor spacer that people have reported to work. Basically spaces the sensor out and has a tiny cat before the sensor. Again hit or mis I'm guessing.
Old Oct 18, 2013 | 09:16 AM
TheBigChill
I've seen that one as well. I've had great success with the Vibrant product, due to it's flexibility through offering 3 different inserts.
Old Oct 18, 2013 | 09:31 AM
lowsid3r's Avatar
lowsid3r
Or just tune it out
Old Oct 18, 2013 | 10:46 AM
c0op3r's Avatar
c0op3r
Kimolaoha
Jul 5, 2023 01:04 PM
emulajavi
Dec 24, 2018 09:15 AM
mdutton11
14
Oct 26, 2015 01:47 PM
