Tire recommendation
Old Oct 7, 2013 | 02:23 AM
Sin MINI's Avatar
Sin MINI
Tire recommendation
My Yokohamas are in need of replacement and I did not like them. No traction in turns and no tread life. Can somebody recommend a summer performance tire that is:
  • modestly priced
  • handles OK in the rain (Doesn't happen often but when it does the crazies come out and I want to be able to avoid them )
  • good tread life
I tried General Exclaims before and they simply did not hold up...blew through three of them. Found the Hankook Ventus V12 evo K110 on Tire rack, curious if it's any good?
Old Oct 7, 2013 | 08:04 AM
cristo's Avatar
cristo
Alliance Member
what size tires?
which Yokos did you have?
The Continental ExtremeContact DW max performance summer tires are comfortable, wear well,
are good in the dry, moderately priced, are lighter than average, are available in 205/50/16 and
205/45/17, and are fantastic in the wet.
It also got better survey results than the Hankook Ventus V12 evo K110 on Tire Rack.
Old Oct 7, 2013 | 09:10 AM
Sin MINI's Avatar
Sin MINI
I don't recall which Yoko, but I run stock 205/45/17. And thanks for the recommendation...those look good.
Old Oct 7, 2013 | 09:49 AM
cristo's Avatar
cristo
Alliance Member
Another to seriously consider in 205/45/17 is the Bridgestone Potenza S-04 Pole Position.
It's only $104 now and although a bit heavier than the Cont DW, it's overall a little better
tire than the DW.
Kimolaoha
Dec 5, 2020 09:32 PM
HaveATank
Sep 4, 2015 08:04 AM
LZRBLUE
Aug 28, 2015 10:31 AM
theateist
Aug 22, 2015 06:58 AM
sabjcw
Aug 14, 2015 07:40 AM
