Coolant Turning Black
Old Sep 30, 2013 | 01:56 PM
gknorr's Avatar
gknorr
Did a thorough coolant flush about 3 months ago to switch from Preston Extended Life back to BMW blue. Put in 50/50 mix and a half bottle of Redline Water Wetter.
Popped the bonnet to check the oil today and noticed the coolant is starting to turn from BMW blue to black. In the past as the coolant has deteriorated it's turned more of an orange color.
No sign of coolant in the oil and this doesn't really seem to be oil in the coolant, so I don't think it's a head gasket.
Anyone else have this happen? A quick google search seemed to point to the water wetter as the culprit. Didn't happen the last time I used it, but the last was with Preston Extended Life coolant, not the BMW stuff. Maybe it just reacts differently with BMW coolant.
Attached Thumbnails Coolant Turning Black-dscf0112.jpg   Coolant Turning Black-dscf0114.jpg
Old Oct 1, 2013 | 10:18 AM
Nitro Jake's Avatar
Nitro Jake
looks pretty normal. its not sludgy is it?
Old Oct 1, 2013 | 12:54 PM
gknorr's Avatar
gknorr
No sludge as far as I can tell - might try to drain the reservoir tonight to get a better look at it and compare to fresh side-by-side.
I agree, it doesn't seem too bad, but it does seem to be getting more black than when I first put it in 3 months ago.
Old Oct 1, 2013 | 03:27 PM
gknorr's Avatar
gknorr
Sifted through some old pictures and found one from replacing my valve cover gasket that shows what the coolant looked like about 2 months ago - definitely bluer.
Something's going on with it, but it's hard to say what at this point. Will probably try a thorough flush and refill first when I get a chance.
Old Oct 1, 2013 | 07:11 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
My guess is that is the color you get if the preston was green/orange and then you drained and put in the blue... you will never get all of one type of antifreeze out...so you end up with that color...best thing to do is change it again.. but I don't think you have anything wrong..lol
Old Oct 1, 2013 | 07:22 PM
gknorr's Avatar
gknorr
Good point. I flushed it with distilled water what must have been 8-10 times and it was coming out pretty clear after that, but it probably still had some of the Preston left. There were also probably trace amounts of the cleaner I used too (Gunk C2124).
Guess I'll be flushing again soon...was hoping I was set for a few years the last time!
Old Oct 1, 2013 | 07:27 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
If you flushed it with water...do you mean you just rinsed it through or did you run the motor for a bit?
Old Oct 1, 2013 | 07:35 PM
gknorr's Avatar
gknorr
Ran it each time for 5 minutes or so, so the water would mix with whatever antifreeze was left. The whole process took what seemed like forever for it to start coming out clear.
Old Oct 1, 2013 | 07:41 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I know...it does seem like it takes forever... My bet is that you got the majority of it out but there were pockets of the other antifreeze that never circulated.. like the heater core... So you did it correctly.. I would just change it again if you feel up to it.. other then that I think your car is fine.. I had the same thing happen to me back when I changed from one color to the other..then went back to the blue.. Im going to stay with the blue from now on ha ha...good luck !
Old Oct 1, 2013 | 07:49 PM
gknorr's Avatar
gknorr
Yeah, I'm sticking with blue from now on too.
Here's to hoping another round of flushing clears things up. Might get to it this weekend...
Cereall
Sep 5, 2019 06:05 PM
Dec 23, 2015 10:36 AM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
bctf1
Aug 6, 2015 12:55 PM
