Oil Dipstick guide tube
How many r53 owners have had their oil dipstick guide tube leak lots of oil? Just replaced the supercharger, and noticed that there was an oil leak and it looked to be centered around the guide tube, but even with the bolts undone, we could not pull the tube out, is there a trick? I am sure it is the o-ring on the end of the tube.
Comments, tips?
Comments, tips?
+1 on the twist method while pulling up. Just make sure everything is unbolted on the tube and there is only one seal at the base.
O - Ring 11.81 X 2.6 Bottom of the dipstick tube. Part # 11437513891
http://www.ecstuning.com/Search/SiteSearch/11437513891/
Thanks and good luck.
You are welcome,
Yea the pics help. Good luck.
Its calculated on check out, you add to cart, add your location zip code, then continue and select what method you want to ship with to see the prices.
devicemanager
Jun 17, 2016 06:18 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
