R56 Cooper vs S engine differences?
Old Sep 29, 2013 | 11:03 AM
Speedy400's Avatar
Speedy400
Can someone point me to some reference data or explain the basic engine differences between the Cooper and S bedsides the turbo? Are there any other differences in the block, pistons, cams, valves etc?
What is the biggest contributor to carbon buildup and does the Cooper seem to have less of a problem with that than the S?
And are the manual transmissions the same?
Old Sep 29, 2013 | 05:27 PM
countryboyshane's Avatar
countryboyshane
N14 Cooper S engine is direct injection. That's the biggest contributor to carbon buildup. Every direct injection engine has that problem. Even Porsche and Audi!
Old Sep 29, 2013 | 05:52 PM
KennyR's Avatar
KennyR
The manual trans and clutch are the same in the Cooper and Cooper S.
Old Sep 29, 2013 | 06:08 PM
danjreed's Avatar
danjreed
The modern (current) engine is the N18.
It has different ECU software, dual VANOS, and a major resign in the PCV area to help prevent the carbon issue.
Ford, and Lexus do not have carbon issues... It's not every manufacturer. The early Euro cars made some mistakes, but all seem to be doing much better now.
Old Nov 10, 2013 | 07:59 PM
wwwest's Avatar
wwwest
How to Reduce Carbon Build Up??
I have 2007 MCS, what is my best bet to Prevent most of the Carbon build up?
Catch Can or the blocks that are sold to go in the PCV lines, or?
Old Nov 10, 2013 | 08:14 PM
danjreed's Avatar
danjreed
Originally Posted by wwwest
I have 2007 MCS, what is my best bet to Prevent most of the Carbon build up? Catch Can or the blocks that are sold to go in the PCV lines, or?
I don't think you can prevent it... Only slow it down. I think a combination of catch can, PCV block, and Seafoam fogger are all good ways to slow it down.
Old Nov 10, 2013 | 11:00 PM
Systemlord's Avatar
Systemlord
Do not block any PCV ports without also using an OCC, otherwise all that oil will soak the intake with oil! OCC can slow the carbon buildup but not stop it completely, OCC is better than nothing.
Old Nov 12, 2013 | 04:47 PM
user 7398330's Avatar
user 7398330
N/a
Old Nov 12, 2013 | 04:53 PM
danjreed's Avatar
danjreed
Originally Posted by Andrew Handlen
I dont have an occ on yet and havent had my intake "soaked in oil" ive checked it consistently as well as turbo tubes and the intercooler tubes. Been about 3 months. Car is driven every day. Been about 4k miles put on since doing it.
PCV has a very real function, mainly to vent crank pressure (under load/boost) from the crank area (oil pan). Pressures must be vented (and scavenged) to prevent external oil leaks and sludge.
While the stock N14 Mini/Peugeot design sucks, you should still have some method to vent crank pressures.
Trust me, your putting a TON of stress on gaskets and seals in the engine.. Rear main, crank, oil pan, cam cover.. etc.
You should never block off 100% of the ports.
Old Nov 12, 2013 | 05:00 PM
user 7398330
N/a
Old Nov 12, 2013 | 05:12 PM
danjreed's Avatar
danjreed
I never said i blocked 100% of the ports. Clearly that wouldnt make sense considering im talking about if my intake filter is covered or in your words "soaked" in oil. Passenger side blocked. Been fine for 3 months. Within that 4k of mileage are multiple trips from CA to AZ. No problems.
Please see link below. Specifically post #11.
http://www.mini2.com/forum/second-ge...se-delete.html
Sorry, the way you had replied to the post above yours it sounded like you were saying you had blocked off 100% of the ports and all was still ok.
And I didn't say soaked in oil, the other dude did. Passenger side block offs are perfectly fine.
drichburg
R60/R61 Stock Problems/Issues
Jun 28, 2014 04:17 PM
vger105
Oct 1, 2013 02:17 PM
Peppershaker
Mar 31, 2012 04:40 PM
Ween
Apr 18, 2011 06:48 PM
rimtnbiker
Jan 10, 2011 06:51 PM
