R56 Clearcoat problem
Old Sep 24, 2013 | 08:09 PM
AaronTalks's Avatar
AaronTalks
Clearcoat problem
So I took the stripes off my r56 the other day planning on putting an offset stripe down. To my amazement the previous owner had some damage and got the car repainted but didn't take off the stripes so there are indentations around the stripes (clear coat). Thinking about doing a wetsand/buff to try and get them even with the rest of the coat. Took it to a car paint place and was quoted $700 to repaint...the easiest solution is to buy stripes and put em back but what are your thoughts?
Old Sep 24, 2013 | 09:33 PM
kaneguy's Avatar
kaneguy
Repainting would be you last option. Laying new stripes would work. Hopefully you are able to find stripes with the same dimensions otherwise there maybe a very small indentation where the old stripes were. Another option would be spray a few coats of clear to build up the section where the old stripes were. I think building up the clearcoat would be safer than sanding the old coats to level it.
Old Sep 25, 2013 | 03:46 AM
Beachnmini's Avatar
Beachnmini
That won't work, I'm sorry. It'll make things worse. You're only hope is to scuff and reshoot the clear on the whole hood.
Old Sep 26, 2013 | 07:06 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
At a minimum you are going to need to wet sand/block out the ridges, then your best option would be to scuff and re clear the hood.
It'll be a couple hundred $ in a body shop, and 80% of that is going to be labor. :(
Old Sep 28, 2013 | 08:21 AM
AaronTalks's Avatar
AaronTalks
no good. may just buy some bonnet stripes and hope for the best...
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
