Why you should check your mounts if you suspect mushrooming
Old Sep 23, 2013 | 11:26 AM
Mr Apex's Avatar
Mr Apex
Hey all,
Just another example of why it is wise to check your top strut mounts if you suspect tower mushrooming.
When I got the car, I saw I had mushrooming, but believed it was limited to only the towers. After buying CravenSpeed Defenders I attempted to fit them before flattening and realized that the studs did not even come close to fitting inside the holes in the plate. After this finding I ordered and replaced my strut mounts this weekend.
Yes the job can be a pain if you have the tools to do it yourself (especially if you break the pinch bolt, but I got lucky with mine.) But I feel that if you're going to fix it, fix it right and forget it.
Attached are some pictures of the strut mount carnage.
Don't think I have to worry too much with the defenders on
Attached Thumbnails Why you should check your mounts if you suspect mushrooming-passenger-strut-mount.jpg   Why you should check your mounts if you suspect mushrooming-driver-strut-mount.jpg
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Etrain
11
Aug 20, 2015 10:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
kwijmbo
Aug 5, 2015 09:00 PM
